Revive uzb stick by uart?
khag
Post by khag »
Hi
wondering if its possible to reprogram/revive a bricked uzb stick by uart connection and if possible to know what pinout needed for it?
Also if its possible to reprogram the chip by z wave programmer by silabs:
https://www.silabs.com/community/wirele ... overi-5sGv
my update came as far as this, afterwards the stick wouldnt work:
[2020-11-21 16:23:51.123] [D] [zway] Opened device: \\.\COM4
[2020-11-21 16:23:51.123] [W] [i/o] Failed to alter device settings: 31
[2020-11-21 16:23:51.123] [D] [zway] Worker thread successfully created
[2020-11-21 16:23:51.123] [D] [zway] Worker thread entry point
[2020-11-21 16:23:51.139] [I] [zway] Adding job: Get controller info and supported function classes
[2020-11-21 16:23:51.150] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2020-11-21 16:29:32.417] [C] [i/o] Serial port write error: The I / O operation has been terminated due to a thread termination or a request from an application.
Re: Revive uzb stick by uart?
If USB is not available anymore, then no way to use USB ;(
UART/SPI methods requires special toolings and software.
khag
Post by khag »
Hi
Yes I am aware that I can't use the USB anymore, but as asked earlier. What's the pinout required to flash the chip by uart?
I have a USB to ttl adapter for the communication, but there doesn't seem to be any document telling which pinout to connect to, on the board for the Uzb stick you have rx, tx, 5v, 3v3, rst, grd and sck.
Have tried with 3v, grd, rst, tx and rx connection but no luck.
