Razberry node
Clusty
Razberry node
Post by Clusty »
I was wondering if I could use a raspberry+razberry shield as a regular node to send environmental sensor data to my existing zwave controller ( smart things ).
I see no programming doc and all examples talk about creating a controller from the raspberry.
Re: Razberry node
RaZberry is made to be a controller. For sensors better use Z-Uno.
But SmartThings requires special templates for devices and you will need to make own template
Clusty
Re: Razberry node
Post by Clusty »
I am kinda stuck between a rock and a hard place: one of the devices is usb based and would need to figure out how to get an arduino to act as a usb host ( guess need extra hardware )
Re: Razberry node
Z-Uno is like an Arduino. No need for extra hardware
Clusty
Re: Razberry node
Post by Clusty »
PoltoS wrote:
02 Jan 2021 18:54
Arduino cannot be a usb host ( only a usb slave device ) without extra hardware and some abandoned library.
Re: Razberry node
Why do you need USB host? You can connect your sensors via analog/digital pins to the Z-Uno
Clusty
Re: Razberry node
Post by Clusty »
PoltoS wrote:
02 Jan 2021 23:33
Not this one. It’s a apogee sq-420
It does serial over usb.
