Primary and Secondary Gateways - Can I assign both to Association Group 1 (Lifeline)?
sofakng
Post by sofakng »
If I have a primary and secondary gateway, can I have both gateways receive device updates?
For example, the GE/Jasco 55258 Fan Controller supports up to 5 nodes in Association Group 1 (Lifeline).
Can I set both my primary and secondary gateway to Group 1 to receive updates from the switch? Is this the correct way to have multiple gateways receive status updates?
Re: Primary and Secondary Gateways - Can I assign both to Association Group 1 (Lifeline)?
Correct!
Unfortunatelly some devices can host only up to 1 device in the Life Line group (#1). But in your case it is 5 - you are on the safe side
sofakng
Post by sofakng »
Thanks so much for the help!
I've successfully associated group gateways to Group 1 (Lifeline) and if I physically press the button, both gateways receive the status update.
However, if I use either gateway to remotely control the switch, the other gateway doesn't get updated.
Is this normal?
lanbrown
Post by lanbrown »
sofakng wrote:
23 Jun 2021 04:32
Is this normal?
Yes, Jasco doesn't send updates when it is remotely controlled. It sends an update when it is locally controlled. They also don't provide firmware updates; so even if they decided to fix this issue (been there for many years) then it wouldn't help you since they don't offer updates.
So you would need to figure out a way to have both gateways perform a period update check to the Jasco devices so they are in sync. How often would depend on what the gateway can be configured for and how busy your z-wave network is.
