3.2.0 release but no changelog
vinisz
Post by vinisz »
I can see 3.2.0 is released, but there is no changelog.
Why is that and what are the changes
Re: 3.2.0 release but no changelog
They are here: https://storage.z-wave.me/z-way-server/ChangeLog
On Monday this build will be added in the repository and you will be able to update easily.
GokMasE
Post by GokMasE »
Hi PoltoS, and thanks for the update on the dev changes since 3.1.4.
I have installed the new 3.2.0 and then rebooted the system, but ran into problems at once.
Has something changed in the way you access/address zway since 3.1.4? I can no longer connect to either of these it seems:
http://local-ip:8083/
http://local-ip:8083/expert/
I have read through the change.log a couple of times but can't find anything obvious that indicates the need to address zway differently in order to get it to work. So, do I need to adapt my links somehow, or should I expect that something went wrong with the updating process?
EDIT: After the update, I checked (with "top") and noticed that there is no z-way-server listed as running anymore, I suppose that suggests the updating process must have been going very wrong. Reverting to 3.1.4 will fix this problem.
This is with "Raspbian GNU/Linux 9 (stretch)" on an RPi3 btw.
Thank you in advance,
Regards,
/Joakim
Could you please contact us by mail and provide more info including logs?
GokMasE
Post by GokMasE »
Yes absolutely, I will do later today/evening (as soon as the kids are asleep).
In order to prepare for gathering good information, which log files except z-way-server.log are of interest in this situation?
/Joakim
vinisz
Post by vinisz »
PoltoS wrote:
28 Aug 2021 23:56
Thanks, lot's of work done I see... compliments, great job!
Now only thing waiting for is the gen7 pro to buy in Europe.
vinisz
Post by vinisz »
@poltos, just upgraded, it says "upgrade succesfull" but it is still on 3.1.4 , even after reboot
kosinus33
Post by kosinus33 »
Same problem here
It is public now. Please try once again. We still wait the iOS app to be reviewed to make the announcement
vinisz
Post by vinisz »
PoltoS wrote:
01 Sep 2021 04:20
Confirmed, working now, just upgraded...
