After upgrade to 3.2.0 , all devices descriptions are gone
vinisz
Post by vinisz »
HI,
Just verified that after 3.2.0 , all device descriptions are gone.
Looks like the DB is empty but also what was attached as device description is not attached anymore.
Also no longer able to set associations now (blank screen)
@poltos, can this be fixed very soon ?
And how can I roll-back to 3.2.1 easiest ? (I have backups also, but what should I restore ?)
Re: After upgrade to 3.2.0 , all devices descriptions are gone
The update should not affect your devices. Please provide us access so we check your system
vinisz
Post by vinisz »
Sure, how do I do that ?
Second, is there an option to downgrade ?
You can downgrade, but please first check for a backup in /opt folder.
vinisz
Post by vinisz »
I did the downgrade, everything is working again.
I leave it up to you to further investigate the 3.2.0 build cause I think, also if I look at other posts, there is some work to do here.
TexasRebel
Post by TexasRebel »
How did you downgrade, and where in the /opt directory would I confirm a backup exists?
Looks like we found the issue. We will make a fix next week and let you test if your issue is gone.
Vovven
Post by Vovven »
Device descriptions still missing after upgrade to 3.2.1
pdekuewit
Post by pdekuewit »
The same here, some devices are complete, some devices have no configuration info nor associations (blank screens) Problem occurs with 3.2.0 and 3.2.1
Go in /opt/z-way-server/ZDDX and run ./UpdateXML.sh
We will fix it soon.
