Error linking with some functions with argument variable not computed during compilation. [solved]
element
Post by element »
log(1.2);		//OK
float x=1.2; log(x);	//OK
log(analogRead(A1));	//Error
sqrt(analogRead(A1));	//Error
abs(analogRead(A1));	//OK
sin(analogRead(A1));	//OK
linking "test2_ino.elf"                  ..............................                        FAILED
          C:\Users\duch\AppData\Local\Temp\arduino_build_672289\\test2_ino.opp: In function `loop()':
          test2_ino.cpp:(.text._Z4loopv+0xc): undefined reference to `log'
          collect2.exe: error: ld returned 1 exit status
amatilda
Re: Error linking with some functions with argument variable not computed during compilation.
Post by amatilda »
Hello.
There was a small bug in the package, which was fixed without changing the version of the package. Therefore, you need to reinstall in order to download the updated package.
element
Post by element »
I downloaded packages again but they haven't changed. I started looking for what else to reinstall and found a new address for downloading packages.
I was typed:
https://rus.z-wave.me/files/z-uno/g2/be ... index.json
I changed to:
https://z-uno.z-wave.me/files/z-uno2/pa ... index.json
And now the packages have changed. Thanks amatilda :-)
