firmware update to 3.2.1
stereomc
Post by stereomc »
Hi guys!
Trying to update the firmware from 3.1.1 to 3.2.1 via RaZberry Configuration Interface.
It is starting Installer downloading (1 sec), than Installer staring (15 sec) than says "Upgrading successfully finished!"
But when I open up this page again it shows again 3.1.1 as a current version.
So - no upgrade and I assume it should not be like that.
Any help?
Re: firmware update to 3.2.1
Please do the OS upgrade in the terminal
sudo apt-get update
sudo apt-get upgrade
Then use the UI to upgrade again or upgrade from the terminal like described on our site https://z-wave.me/z-way/download-z-way/
stereomc
Post by stereomc »
Sorry for the question...where to find a terminal? Using just z-wave smarthome interface
enbemokel
Post by enbemokel »
Try "Putty" for the terminal login.
raikab
Post by raikab »
sorry, I don't understand. The update to 3.2.1 works only in therminal?
I am only conected with Networkcable to my Raspberry and works with smart home UI.
wats the solution in this case?
enbemokel
Post by enbemokel »
No, it works also in the z-wave interface, but if it´s not working, Polto mentioned to update the OS
sudo apt-get update
Thats the terminal and you need e.g. Putty.
But maybe you just restart your raspberry and try again. Sometimes a restart is like a miracle.
raikab
Post by raikab »
thank you!
update to 3.2.1 has now succeeded.
But...in expert UI the Device Description is missing?
This will be healed in 3.2.2. It is under test now.
