Aotec Repeater 7 Security S2 key negociation
J.nissen
Post by J.nissen »
interview for S2 Security failed
Any Tip ?
SendData Response with callback 0x37 received: received by recipient
[2022-05-01 18:24:49.281] [D] [zway] SETDATA devices.35.data.lastSendInternal = **********
[2022-05-01 18:24:49.281] [D] [zway] SETDATA devices.35.data.lastSend = 16197429 (0x00f72735)
[2022-05-01 18:24:49.281] [D] [zway] Job 0x13 (Security S2 KEX Get to node 35): success
[2022-05-01 18:24:49.281] [zway] Removing job: Security S2 KEX Get to node 35
[2022-05-01 18:24:53.546] [D] [zway] Job 0x3b: deleted from queue
[2022-05-01 18:24:59.391] [D] [zway] Security S2 inclusion timeout event
[2022-05-01 18:24:59.392] [W] [zway] Node 35:0 CC SecurityS2: Security S2 key negociation with node 35 failed, KEX fail reason: Unknown Security S2 KEX failure reason (0)
[2022-05-01 18:24:59.393] [D] [zway] SETDATA devices.35.instances.0.commandClasses.159.data.securityAbandoned = True
[2022-05-01 18:24:59.393] [D] [zway] SETDATA devices.35.instances.0.commandClasses.159.data.grantedKeys.S0 = False
[2022-05-01 18:24:59.393] [D] [zway] SETDATA devices.35.instances.0.commandClasses.159.data.grantedKeys.S2Unauthenticated = False
[2022-05-01 18:24:59.393] [D] [zway] SETDATA devices.35.instances.0.commandClasses.159.data.grantedKeys.S2Authenticated = False
[2022-05-01 18:24:59.393] [D] [zway] SETDATA devices.35.instances.0.commandClasses.159.data.grantedKeys.S2Access = False
[2022-05-01 18:24:59.393] [D] [zway] SETDATA devices.35.instances.0.commandClasses.159.data.grantedKeys = False
[2022-05-01 18:24:59.393] [D] [zway] SETDATA devices.35.instances.0.commandClasses.159.data.interviewCounter = 0 (0x00000000)
[2022-05-01 18:24:59.393] [zway] Saving configuration data to config/zddx/fef5a792-DevicesData.xml
[2022-05-01 18:24:59.639] [zway] Interview step 4 skipped due to absence of MultiInstance CC
[2022-05-01 18:24:59.639] [zway] Interview step 5
[2022-05-01 18:24:59.639] [zway] Node 35:0 CC SecurityS2 Interview abandoned due to many retries
[2022-05-01 18:24:59.639] [zway] Saving configuration data to config/zddx/fef5a792-DevicesData.xml
[2022-05-01 18:24:59.779] [D] [zway] SETDATA devices.35.data.keepAwake = False
[2022-05-01 18:24:59.779] [zway] Interview for Node #35 failed. Try to force interview or re-inclusion.
[2022-05-01 18:24:59.779] [W] [zway] Security S0/S2 bootstrap failed
[2022-05-01 18:24:59.779] [D] [zway] Own inclusion - nothing to report to inclusion controller
[2022-05-01 18:25:03.341] [zway] Adding job: Get background noise level
[2022-05-01 18:25:03.341] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-01 18:25:03.343] [D] [zway] RECEIVED ACK
[2022-05-01 18:25:03.344] [D] [zway] RECEIVED: ( 01 07 01 3B A1 9E 9E 7F 1C )
[2022-05-01 18:25:03.344] [D] [zway] SENT ACK
[2022-05-01 18:25:03.344] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 161 (0x000000a1)
[2022-05-01 18:25:03.344] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 158 (0x0000009e)
[2022-05-01 18:25:03.344] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 158 (0x0000009e)
[2022-05-01 18:25:03.344] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -95 dBm, Ch#2: -98 dBm, Ch#3: -98 dBm
[2022-05-01 18:25:03.344] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-01 18:25:03.345] [zway] Removing job: Get background noise level
[2022-05-01 18:25:09.889] [D] [zway] Job 0x13: deleted from queue
Greetings from germany
Jörg
Re: Aotec Repeater 7 Security S2 key negociation
The device just failed to answer to the initial KEX Get. Looks like a device issue
lanbrown
Post by lanbrown »
This doesn't answer your question but something to think about. I never saw the advantage of the standalone repeaters. Most mains powered devices act as a repeater so a mesh network is created. The price of the repeater is the same as a main powered switch. So I would rather spend the money on a switch than a repeater. You get more for the money since you now have a Z-Wave switch to use. The repeater takes an electrical outlet, you could install a Z-Wave electrical outlet. There is also the plugin outlets as well.
