Aeotec - ZW112-A won't interview completely
lanbrown
Post by lanbrown »
I have an Aeotec ZW112 window/door sensor and it will only get to 64% on the interview. I can click on force interview but the same classes always do not complete.
First class that doesn't complete is AssociationGroupInformation
/: None (09:17)
    supported: true (09:17)
    version: 1 (09:17)
    security: false (09:17)
    interviewDone: false (09:17)
    interviewCounter: 9 (09:17)
    dynamic: None (09:17)
The second class that doesn't complete is ZWavePlusInfo
/: None (09:17)
    version: 1 (09:17)
    plusVersion: None (09:17)
    roleType: None (09:17)
    nodeType: None (09:17)
    installerIcon: None (09:17)
    userIcon: None (09:17)
    roleTypeString: None (09:17)
The third class that doesn't complete is PowerLevel
/: None (09:17)
    version: 1 (09:17)
    level: None (09:17)
    timeout: None (09:17)
The fourth class that doesn't complete is Association
/: None (09:17)
    version: 1 (09:17)
    groups: None (09:17)
    specificGroup: None (09:17)
The last class that doesn't complete is Version
/: None (09:17)
    32: None (09:17)
    48: None (09:17)
    89: None (09:17)
    90: None (09:17)
    94: None (09:17)
    112: None (09:17)
    113: None (09:17)
    114: None (09:17)
    115: None (09:17)
    122: None (09:17)
    128: None (09:17)
    132: None (09:17)
    133: None (09:17)
    134: None (09:17)
    version: 1 (09:17)
    ZWLib: None (09:17)
    ZWProtocolMajor: None (09:17)
    ZWProtocolMinor: None (09:17)
    SDK: None (09:17)
    applicationMajor: None (09:17)
    applicationMinor: None (09:17)
    hardwareVersion: None (09:17)
    firmwareCount: None (09:17)
It was device 9 and I excluded it and then included it and it is now device 10.
Re: Aeotec - ZW112-A won't interview completely
Is it on v3.2.3? Please provide the inclusion log (here or by mail)
lanbrown
Post by lanbrown »
Yes. 3.2.3. I'll have to send it via email as when I tried to add it initially it was too long.
bany
Post by bany »
could you fix the issue?
mcleanross3
Post by mcleanross3 »
Waiting for your response on this matter
GregN
Post by GregN »
Hi lanbrown,
I too have been having problems with my ZW112s. I have tracked down the problem to the time that it takes Z-Way (a RazBerry Gen 7 running 7.28 and Z-Way 3.2.3 in my case) to do the interview vs the time that the ZW112 stays awake (only 10 seconds).
If you put the ZW112 into its 10 minute wake-up mode (press and hold the action button for 3 seconds until led flashes orange) and then request NIF and force interview then hopefully the interview will complete.
HTH
Greg
