This is my first post here and I created account since I have run into a issue regarding the installation of Z-wave.me for raspberry pi 3.
I have Razberry top on my pi and I have rasp OS (bullseye) installed. I am beginner in linux based programs and I am trying to set up a Z-wave environment.
I followed the instructions on https://z-wave.me/z-way/download-z-way/ section: "First installation when Raspberry Pi is already up and running"
with command wget -qO - https://storage.z-wave.me/RaspbianInstall | sudo bash
This leads on failure to install due to packages missing such as libssl1.0.2:armhf, z-way-server and webif. z-way-full is depended on these ones.
What can be done? My next step is to install Z-wave environment with image provided.
Thank you.
Raspberry pi 3 installation on Rasp OS fails
Re: Raspberry pi 3 installation on Rasp OS fails
Have you considered using a commercial Z-Wave controller such as the Aeotec Smart Hub? They provide a plugin-and-go experience.
As you've discovered, a linux-based DIY Z-Wave controller can be frustrating. Starting with the Z-Way image is a good idea.
1) Are you using the 64-bit image of Raspian Bullseye?
If YES, then you need to use the 32-bit image
If NO, then re-run the install.
