PoltoS wrote: ↑16 Jun 2022 01:46
Hello!
What do you mean by "I do not see the Energy Driven Switch but only the ZWave double switch". Where do you see it?
"Impossible to include" means it is not included at all? Or it is not included as you expected? Please provide more details.
Hi Poltos, thank you for your reply.
In the Zway vendors page, I see the WiDom icon and if I click on it, in the products page I see only one device named "Z-Wave Double Switch".
If I select this device and try to add the device to my Z-wave network, the inclusion process do not works.
I tried also the inclusion using the option "Add new Z-Wave DEvice and identify it automatically" but also in this case the inclusion process do not works.
The vendor instructions decribes the inclusion process in this way:
the device supports the Network Wide Inclusion (NWI) and the Normal Inclusion
A single click on the B button starts the normal inclusion and after 2 seconds , if the controller do not start the normal inclusion, it will start the NWI.
I tried to follow this instructions but nothing appens. If i click in the "Start" button in the "Add new device" window, after some minute the ZWay shows the window "SmartHome UI - Warning" - "INCLUSION takes too long to start up"
Where is the problem? Maybe I'm doing something wrong?
Thank you for your attention,
best regards,
Miklux
