I'm struggling with getting MxMQTT to read/show the separate values being sent from a Mi Flora sensor via a broker.
This is the text that is sent to the topic if listening with mosquitto_sub:
Client received PUBLISH (d0, q0, r0, m0, 'miflora/villav-Mi_Flora', ... (85 bytes))
{"light": 245, "temperature": 23.2, "moisture": 6, "conductivity": 0, "battery": 100}- MxMQTT is connected to the topic and is receiving
- Reading from Multiline device says "[object Object]⋯ ".
- I'm suspecting that it's "the Displayed Value (Level)"-field under "Create Virtual Devices for Single Topics" that's the culprit?
Using this handy solution: https://github.com/ThomDietrich/miflora-mqtt-daemon
Yours
moj
