I was wrong. Please delete post
sergrossi
Post by sergrossi »
- del
Raspberry Pi 4, Raspberry Pi OS Lite (Debian version: 11 (bullseye),
Z-Way for Raspberry Pi, RaZberry 7 Pro, RaZberry 2
lanbrown
Re: Z-Way. Impossible to get into Razberry Configuration Interface
Post by lanbrown »
Creating another thread for the same thing is even worse!
You also never answered the questions given. You just created another thread for the same issue.
This issue is a Z-Way issue, it isn't an issue with the Razberry boards. The issue is in your configuration of your Raspberry Pi's.
Since it is like pulling teeth to get you to answer questions.....good luck with YOUR problem. I'm done assisting you.
alexis92
Post by alexis92 »
I'm not even very sure what difference it would make to create another thread to ask the same question instead of going along the troubleshooting process on the existing thread...
