Hi community,
I´m Norbert - from Germany.
I use UZB and Z-Way Software successfully on different Windows PC´s.
Now I gut 2 new mini PC´s one with Win10 pro, the other with Win 11 pro.
When installing z-way-server-windows-v3.2.1 and others,
installation almost runs through ...
until the Services are going to be started ...
after 5 sec. the installations causes the above error.
Options are "retry" and "abort"
I changed the Service-Start timeout in the registry
checked the user permissions
asked Dr. Google ...
and I have no clue left ';)
maybe you had the same issue and solved it already -
or any ideas are welcome.
thanks and kind regards
Norbert
Windows Z-Way Service (ZWaySvc) could not be started
Re: Windows Z-Way Service (ZWaySvc) could not be started
Hello!
Looks like the Z-Way service fails to start. There should be a log in the c:\program files\z-way server folder. Please open it and show the error.
Which of the mini-PCs are you facing the error on? The one with Win10 or Win11?
Good morning,
thanks PoltoS and Alexis92 for your comments and questions.
It happened on both mini PC´s ... Win10 and Win11
Searching for the log file, I found the file: z-way-svc
When executing the file, a more specific error came up: VCruntime140.dll missing
I downloaded (from Microsoft) and reinstalled the VC Library - no success.
I noted that z-way installed in programs(x86) directory.
Downloaded the x86 Version of the VC Library, installed it
and now it works like usual
Thanks again
best regards
Norbert
Thanks again
best regards
Norbert
