support: 26 03
fez
support: 26 03
Post by fez »
I have been ignoring this issue for some time:
[W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 26 03
[W] [zway] Got unsecure packet from device 22, but Command Class 0x26 SwitchMultilevel is marked as secure and not present in unsecure NIF. Ignoring packet.
[E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
Device 22 is a Roller Shutter FGRM-222.
Some advice how to handle this would be welcome.
Re: support: 26 03
We need more [D] lines just before it. But I suppose the device reported its state insecurely, while it was added with security.
In v4.0.0 we will dramatically improve the security policy and many such errors might go away.
fez
Re: support: 26 03
Post by fez »
Thanks.
I guess I'll just wait it out than.
fez
Re: support: 26 03
Post by fez »
I actually have a second issue, which falls in this category after looking into the logs. Some of my Fibaro devices (button, swipe) send Central Scene Notifications. I see these in the Zniffer, but these don't show in the Zway events and rules activated by these don't work.
I found this in the logs:
[...869] [D] [zway] RECEIVED: ( 01 12 00 04 00 4A 09 60 0D 00 00 5B 03 32 00 02 C3 00 00 6C )
[...870] [D] [zway] SENT ACK
[...870] [D] [zway] SETDATA devices.74.data.lastReceived = 0 (0x00000000)
[...870] [W] [zway] Ignoring packet recieved on lower security scheme Plain text than device highest S0
[...870] [E] [zway] Error returned from (returnStatus = _zway_cc_call_handler(zway, cmd, node_id, data[3], length - 4, &data[4])): Function class not supported by the hardware (-4)
These use to work just fine. I have not been using these devices for a while, so I don't know when this got broken.
Any suggestions how to fix this would be great.
Re: support: 26 03
Both mean the device is sending unsecure commands, while it is included securely. This happens with buggy devices.
You can set devices[74].data.acceptSetSecurityLevel=0 to allow insecure commands.
fez
Re: support: 26 03
Post by fez »
Where could I do (add) this?
fez
Re: support: 26 03
Post by fez »
I have tried this via the "Load custom JavaScript code" module:
zway.devices[74].data.acceptSetSecurityLevel=0;
... but with no effect
piet66
Re: support: 26 03
Post by piet66 »
try this:
http://IP:8083/ZWaveAPI/Run/zway.devices[74].data.acceptSetSecurityLevel.value=0
You can check with .../ZWaveAPI/Data/0 whether it's stored.
You should check too whether the type is changed from "empty" to "int" or "string".
fez
Re: support: 26 03
Post by fez »
Thanks for the hint piet66.
The type is int. The value has been stored.
... still no effect
Re: support: 26 03
Sorry, it is a report.
This is a device bug - include it insecurely or wait for 4.0.0 to allow to fix it using acceptReportSecurityLevel
