Z-Stick Gen5 (ZW090) Device is not compatible
hodosyp
Post by hodosyp »
I recently brought an Aeotec Z-Stick Gen5 USB stick. I setup Z-way on both Raspberry and Windows but I got the same result "Device is not compatible. Terminating..."
Here is the full output from Raspberry:
[2022-10-05 15:34:27.532] [D] [zway] Opened device: /dev/ttyACM0
[2022-10-05 15:34:27.532] [I] [i/o] Setting port speed to 115200
[2022-10-05 15:34:27.533] [D] [zway] Worker thread successfully created
[2022-10-05 15:34:27.534] [D] [zway] Worker thread entry point
[2022-10-05 15:34:27.544] [I] [zway] Adding job: Get controller info and supported function classes
[2022-10-05 15:34:27.544] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2022-10-05 15:34:27.545] [D] [zway] RECEIVED ACK
[2022-10-05 15:34:27.549] [D] [zway] RECEIVED: ( 01 2B 01 07 01 02 00 86 00 01 00 5A FE 87 7F 88 CF 7F C0 4F FB DF FD E0 67 00 80 80 00 80 86 00 01 00 E8 73 00 80 0F 00 00 60 00 00 90 )
[2022-10-05 15:34:27.549] [D] [zway] SENT ACK
[2022-10-05 15:34:27.550] [D] [zway] SETDATA controller.data.APIVersion = "01.02"
[2022-10-05 15:34:27.550] [D] [zway] SETDATA controller.data.APIVersionMajor = 1 (0x00000001)
[2022-10-05 15:34:27.550] [D] [zway] SETDATA controller.data.APIVersionMinor = 2 (0x00000002)
[2022-10-05 15:34:27.550] [D] [zway] SETDATA controller.data.manufacturerId = 134 (0x00000086)
[2022-10-05 15:34:27.550] [D] [zway] SETDATA controller.data.manufacturerProductType = 1 (0x00000001)
[2022-10-05 15:34:27.551] [D] [zway] SETDATA controller.data.manufacturerProductId = 90 (0x0000005a)
[2022-10-05 15:34:27.567] [D] [zway] SETDATA controller.data.vendor = "Aeotec"
[2022-10-05 15:34:27.567] [D] [zway] Supported Function Classes:
[2022-10-05 15:34:27.567] [D] [zway] ---------------------------
[2022-10-05 15:34:27.567] [D] [zway] 0x02 SerialAPIGetInitData
[2022-10-05 15:34:27.567] [D] [zway] 0x03 SerialAPIApplicationNodeInformation
[2022-10-05 15:34:27.567] [D] [zway] 0x04 ApplicationCommandHandler
[2022-10-05 15:34:27.568] [D] [zway] 0x05 GetControllerCapabilities
[2022-10-05 15:34:27.568] [D] [zway] 0x06 SerialAPISetTimeouts
[2022-10-05 15:34:27.568] [D] [zway] 0x07 GetSerialAPICapabilities
[2022-10-05 15:34:27.568] [D] [zway] 0x08 SerialAPISoftReset
[2022-10-05 15:34:27.568] [D] [zway] 0x09 UNKNOWN
[2022-10-05 15:34:27.568] [D] [zway] 0x0a UNKNOWN
[2022-10-05 15:34:27.568] [D] [zway] 0x0b SerialAPISetup
[2022-10-05 15:34:27.569] [D] [zway] 0x10 UNKNOWN
[2022-10-05 15:34:27.569] [D] [zway] 0x11 UNKNOWN
[2022-10-05 15:34:27.569] [D] [zway] 0x12 SendNodeInformation
[2022-10-05 15:34:27.569] [D] [zway] 0x13 SendData
[2022-10-05 15:34:27.569] [D] [zway] 0x14 SendDataMulti
[2022-10-05 15:34:27.569] [D] [zway] 0x15 GetVersion
[2022-10-05 15:34:27.570] [D] [zway] 0x16 SendDataAbort
[2022-10-05 15:34:27.570] [D] [zway] 0x17 RFPowerLevelSet
[2022-10-05 15:34:27.570] [D] [zway] 0x1c UNKNOWN
[2022-10-05 15:34:27.570] [D] [zway] 0x20 GetHomeId
[2022-10-05 15:34:27.570] [D] [zway] 0x21 MemoryGetByte
[2022-10-05 15:34:27.570] [D] [zway] 0x22 MemoryPutByte
[2022-10-05 15:34:27.570] [D] [zway] 0x23 MemoryGetBuffer
[2022-10-05 15:34:27.570] [D] [zway] 0x24 MemoryPutBuffer
[2022-10-05 15:34:27.571] [D] [zway] 0x27 FlashAutoProgSet
[2022-10-05 15:34:27.571] [D] [zway] 0x28 UNKNOWN
[2022-10-05 15:34:27.571] [D] [zway] 0x29 NVMGetId
[2022-10-05 15:34:27.571] [D] [zway] 0x2a NVMExtReadLongBuffer
[2022-10-05 15:34:27.571] [D] [zway] 0x2b NVMExtWriteLongBuffer
[2022-10-05 15:34:27.571] [D] [zway] 0x2c NVMExtReadLongByte
[2022-10-05 15:34:27.571] [D] [zway] 0x2d NVMExtWriteLongByte
[2022-10-05 15:34:27.572] [D] [zway] 0x2e UNKNOWN
[2022-10-05 15:34:27.572] [D] [zway] 0x2f UNKNOWN
[2022-10-05 15:34:27.572] [D] [zway] 0x37 UNKNOWN
[2022-10-05 15:34:27.572] [D] [zway] 0x38 UNKNOWN
[2022-10-05 15:34:27.572] [D] [zway] 0x39 ClearNetworkStats
[2022-10-05 15:34:27.572] [D] [zway] 0x3a GetNetworkStats
[2022-10-05 15:34:27.572] [D] [zway] 0x3b GetBackgroundRSSI
[2022-10-05 15:34:27.573] [D] [zway] 0x3c UNKNOWN
[2022-10-05 15:34:27.573] [D] [zway] 0x3f RemoveNodeIdFromNetwork
[2022-10-05 15:34:27.573] [D] [zway] 0x41 GetNodeProtocolInformation
[2022-10-05 15:34:27.573] [D] [zway] 0x42 SetDefault
[2022-10-05 15:34:27.573] [D] [zway] 0x44 ReplicationReceiveComplete
[2022-10-05 15:34:27.573] [D] [zway] 0x45 UNKNOWN
[2022-10-05 15:34:27.573] [D] [zway] 0x46 AssignReturnRoute
[2022-10-05 15:34:27.574] [D] [zway] 0x47 DeleteReturnRoute
[2022-10-05 15:34:27.574] [D] [zway] 0x48 RequestNodeNeighbourUpdate
[2022-10-05 15:34:27.574] [D] [zway] 0x49 ApplicationNodeUpdate
[2022-10-05 15:34:27.574] [D] [zway] 0x4a AddNodeToNetwork
[2022-10-05 15:34:27.574] [D] [zway] 0x4b RemoveNodeFromNetwork
[2022-10-05 15:34:27.574] [D] [zway] 0x4c CreateNewPrimary
[2022-10-05 15:34:27.574] [D] [zway] 0x4d ControllerChange
[2022-10-05 15:34:27.575] [D] [zway] 0x4f AssignPriorityReturnRoute
[2022-10-05 15:34:27.575] [D] [zway] 0x50 SetLearnMode
[2022-10-05 15:34:27.575] [D] [zway] 0x51 AssignSUCReturnRoute
[2022-10-05 15:34:27.575] [D] [zway] 0x53 RequestNetworkUpdate
[2022-10-05 15:34:27.575] [D] [zway] 0x54 SetSUCNodeId
[2022-10-05 15:34:27.575] [D] [zway] 0x55 DeleteSUCReturnRoute
[2022-10-05 15:34:27.575] [D] [zway] 0x56 GetSUCNodeId
[2022-10-05 15:34:27.576] [D] [zway] 0x57 SendSUCNodeId
[2022-10-05 15:34:27.576] [D] [zway] 0x58 AssignPrioritySUC ReturnRoute
[2022-10-05 15:34:27.576] [D] [zway] 0x5e ExploreRequestInclusion
[2022-10-05 15:34:27.576] [D] [zway] 0x5f UNKNOWN
[2022-10-05 15:34:27.576] [D] [zway] 0x60 RequestNodeInformation
[2022-10-05 15:34:27.576] [D] [zway] 0x61 RemoveFailedNode
[2022-10-05 15:34:27.576] [D] [zway] 0x62 IsFailedNode
[2022-10-05 15:34:27.577] [D] [zway] 0x63 ReplaceFailedNode
[2022-10-05 15:34:27.577] [D] [zway] 0x66 UNKNOWN
[2022-10-05 15:34:27.577] [D] [zway] 0x67 UNKNOWN
[2022-10-05 15:34:27.577] [D] [zway] 0x78 UNKNOWN
[2022-10-05 15:34:27.577] [D] [zway] 0x80 GetRoutingTableLine
[2022-10-05 15:34:27.577] [D] [zway] 0x90 UNKNOWN
[2022-10-05 15:34:27.577] [D] [zway] 0x92 GetPriorityRoute
[2022-10-05 15:34:27.577] [D] [zway] 0x93 SetPriorityRoute
[2022-10-05 15:34:27.578] [D] [zway] 0x98 UNKNOWN
[2022-10-05 15:34:27.578] [D] [zway] 0xa1 UNKNOWN
[2022-10-05 15:34:27.578] [D] [zway] 0xb4 UNKNOWN
[2022-10-05 15:34:27.578] [D] [zway] 0xb6 UNKNOWN
[2022-10-05 15:34:27.578] [D] [zway] 0xb7 UNKNOWN
[2022-10-05 15:34:27.578] [D] [zway] 0xb8 UNKNOWN
[2022-10-05 15:34:27.578] [D] [zway] 0xb9 UNKNOWN
[2022-10-05 15:34:27.578] [D] [zway] 0xba RFPowerLevelGet
[2022-10-05 15:34:27.579] [D] [zway] 0xbd UNKNOWN
[2022-10-05 15:34:27.579] [D] [zway] 0xbe SendTestFrame
[2022-10-05 15:34:27.579] [D] [zway] 0xbf UNKNOWN
[2022-10-05 15:34:27.579] [D] [zway] 0xd0 SetPromiscuousMode
[2022-10-05 15:34:27.579] [D] [zway] 0xd1 PromiscuousCommandHandler
[2022-10-05 15:34:27.579] [D] [zway] 0xd2 WatchDogStart
[2022-10-05 15:34:27.580] [D] [zway] 0xd3 WatchDogStop
[2022-10-05 15:34:27.580] [D] [zway] 0xd4 UNKNOWN
[2022-10-05 15:34:27.580] [D] [zway] 0xee UNKNOWN
[2022-10-05 15:34:27.580] [D] [zway] 0xef UNKNOWN
[2022-10-05 15:34:27.580] [D] [zway] SETDATA controller.data.capabilities = int[92]
[2022-10-05 15:34:27.580] [D] [zway]   [00] 2
[2022-10-05 15:34:27.580] [D] [zway]   [01] 3
[2022-10-05 15:34:27.581] [D] [zway]   [02] 4
[2022-10-05 15:34:27.581] [D] [zway]   [03] 5
[2022-10-05 15:34:27.581] [D] [zway]   [04] 6
[2022-10-05 15:34:27.581] [D] [zway]   [05] 7
[2022-10-05 15:34:27.581] [D] [zway]   [06] 8
[2022-10-05 15:34:27.581] [D] [zway]   [07] 9
[2022-10-05 15:34:27.581] [D] [zway]   [08] 10
[2022-10-05 15:34:27.581] [D] [zway]   [09] 11
[2022-10-05 15:34:27.582] [D] [zway]   [10] 16
[2022-10-05 15:34:27.582] [D] [zway]   [11] 17
[2022-10-05 15:34:27.582] [D] [zway]   [12] 18
[2022-10-05 15:34:27.583] [D] [zway]   [13] 19
[2022-10-05 15:34:27.583] [D] [zway]   [14] 20
[2022-10-05 15:34:27.583] [D] [zway]   [15] 21
[2022-10-05 15:34:27.583] [D] [zway]   [16] 22
[2022-10-05 15:34:27.583] [D] [zway]   [17] 23
[2022-10-05 15:34:27.583] [D] [zway]   [18] 28
[2022-10-05 15:34:27.583] [D] [zway]   [19] 32
[2022-10-05 15:34:27.583] [D] [zway]   [20] 33
[2022-10-05 15:34:27.584] [D] [zway]   [21] 34
[2022-10-05 15:34:27.584] [D] [zway]   [22] 35
[2022-10-05 15:34:27.584] [D] [zway]   [23] 36
[2022-10-05 15:34:27.584] [D] [zway]   [24] 39
[2022-10-05 15:34:27.584] [D] [zway]   [25] 40
[2022-10-05 15:34:27.584] [D] [zway]   [26] 41
[2022-10-05 15:34:27.584] [D] [zway]   [27] 42
[2022-10-05 15:34:27.584] [D] [zway]   [28] 43
[2022-10-05 15:34:27.585] [D] [zway]   [29] 44
[2022-10-05 15:34:27.585] [D] [zway]   [30] 45
[2022-10-05 15:34:27.585] [D] [zway]   [31] 46
[2022-10-05 15:34:27.585] [D] [zway]   [32] 47
[2022-10-05 15:34:27.585] [D] [zway]   [33] 55
[2022-10-05 15:34:27.585] [D] [zway]   [34] 56
[2022-10-05 15:34:27.586] [D] [zway]   [35] 57
[2022-10-05 15:34:27.586] [D] [zway]   [36] 58
[2022-10-05 15:34:27.586] [D] [zway]   [37] 59
[2022-10-05 15:34:27.586] [D] [zway]   [38] 60
[2022-10-05 15:34:27.586] [D] [zway]   [39] 63
[2022-10-05 15:34:27.586] [D] [zway]   [40] 65
[2022-10-05 15:34:27.586] [D] [zway]   [41] 66
[2022-10-05 15:34:27.586] [D] [zway]   [42] 68
[2022-10-05 15:34:27.587] [D] [zway]   [43] 69
[2022-10-05 15:34:27.587] [D] [zway]   [44] 70
[2022-10-05 15:34:27.587] [D] [zway]   [45] 71
[2022-10-05 15:34:27.587] [D] [zway]   [46] 72
[2022-10-05 15:34:27.587] [D] [zway]   [47] 73
[2022-10-05 15:34:27.587] [D] [zway]   [48] 74
[2022-10-05 15:34:27.588] [D] [zway]   [49] 75
[2022-10-05 15:34:27.588] [D] [zway]   [50] 76
[2022-10-05 15:34:27.588] [D] [zway]   [51] 77
[2022-10-05 15:34:27.588] [D] [zway]   [52] 79
[2022-10-05 15:34:27.588] [D] [zway]   [53] 80
[2022-10-05 15:34:27.588] [D] [zway]   [54] 81
[2022-10-05 15:34:27.588] [D] [zway]   [55] 83
[2022-10-05 15:34:27.588] [D] [zway]   [56] 84
[2022-10-05 15:34:27.589] [D] [zway]   [57] 85
[2022-10-05 15:34:27.589] [D] [zway]   [58] 86
[2022-10-05 15:34:27.589] [D] [zway]   [59] 87
[2022-10-05 15:34:27.589] [D] [zway]   [60] 88
[2022-10-05 15:34:27.589] [D] [zway]   [61] 94
[2022-10-05 15:34:27.589] [D] [zway]   [62] 95
[2022-10-05 15:34:27.589] [D] [zway]   [63] 96
[2022-10-05 15:34:27.590] [D] [zway]   [64] 97
[2022-10-05 15:34:27.590] [D] [zway]   [65] 98
[2022-10-05 15:34:27.590] [D] [zway]   [66] 99
[2022-10-05 15:34:27.590] [D] [zway]   [67] 102
[2022-10-05 15:34:27.590] [D] [zway]   [68] 103
[2022-10-05 15:34:27.590] [D] [zway]   [69] 120
[2022-10-05 15:34:27.590] [D] [zway]   [70] 128
[2022-10-05 15:34:27.590] [D] [zway]   [71] 144
[2022-10-05 15:34:27.591] [D] [zway]   [72] 146
[2022-10-05 15:34:27.591] [D] [zway]   [73] 147
[2022-10-05 15:34:27.591] [D] [zway]   [74] 152
[2022-10-05 15:34:27.591] [D] [zway]   [75] 161
[2022-10-05 15:34:27.591] [D] [zway]   [76] 180
[2022-10-05 15:34:27.591] [D] [zway]   [77] 182
[2022-10-05 15:34:27.591] [D] [zway]   [78] 183
[2022-10-05 15:34:27.591] [D] [zway]   [79] 184
[2022-10-05 15:34:27.592] [D] [zway]   [80] 185
[2022-10-05 15:34:27.592] [D] [zway]   [81] 186
[2022-10-05 15:34:27.592] [D] [zway]   [82] 189
[2022-10-05 15:34:27.592] [D] [zway]   [83] 190
[2022-10-05 15:34:27.592] [D] [zway]   [84] 191
[2022-10-05 15:34:27.592] [D] [zway]   [85] 208
[2022-10-05 15:34:27.592] [D] [zway]   [86] 209
[2022-10-05 15:34:27.593] [D] [zway]   [87] 210
[2022-10-05 15:34:27.593] [D] [zway]   [88] 211
[2022-10-05 15:34:27.593] [D] [zway]   [89] 212
[2022-10-05 15:34:27.593] [D] [zway]   [90] 238
[2022-10-05 15:34:27.593] [D] [zway]   [91] 239
[2022-10-05 15:34:27.593] [D] [zway] ---------------------------
[2022-10-05 15:34:27.593] [D] [zway] Initialization done
[2022-10-05 15:34:27.593] [D] [zway] Job 0x07 (Get controller info and supported function classes): success
[2022-10-05 15:34:27.594] [C] [zway] Device is not compatible. Terminating...
[2022-10-05 15:34:27.594] [I] [zway] Removing job: Get controller info and supported function classes
[2022-10-05 15:34:27.604] [D] [zway] Worker thread exit point
[2022-10-05 15:34:27.605] [D] [zway] Worker thread successfully finished
[2022-10-05 15:34:27.605] [D] [i/o] Closing port
Any idea what is going on here?
lanbrown
Re: Z-Stick Gen5 (ZW090) Device is not compatible
Post by lanbrown »
It is really simple what is going on.....Z-Way cannot natively be used with the Z-Stick. Z-Way is fully compatible with the Razberry board and some features are licensed with a UZB.
https://z-wave.me/z-way/
Z-Way runs on a broad variety of hardware such as Raspberry Pi, PC under control of Windows, Ubuntu or Debian, router based platforms with OpenWRT. To use the Z-Wave functions a Z-Wave.Me hardware such as UZB or RaZberry is needed (*). It consists of various building blocks that can be used together or separate:
Notice this portion:
That asterisk means this:
(*) If you want to run Z-Way on your own platform please check the page Will Z-Way run on my platform and contact us for licensing costs and porting effort estimation.
