Multiple switches in sync
marcin2
Post by marcin2 »
I used domoticz for a long time but had to switch to z-way because of its much better stability and diagnostics tools.
Please advice what is the easiest way to keep three binary switches in sync altogether? I see there is an app called Group Devices but I can make it working.
I don't want to use z-wave associations as I could never get it working on my devices.
Kind regards,
marcin
Re: Multiple switches in sync
Group Devices is good if want to control them from Z-Way. If you want one switch to be copied to others, use three Bind Devices between all three pairs. This will ensure that if one is switched on, others will be switch on too.
