still issues with the 7 Pro
vinisz
Post by vinisz »
I'm on the 700 pro now since couple of weeks (migrated from UZB) , I do however notice that while signals are better (less noise) , performace is not.
The device is having stability issues from time to time, very random also. Sometimes, my lights just did not went on at a certain time, without any reason, other moments, motion sensors don't turn on lights (no difference if controlled via direct association or via node-red)
I cannot pinpoint what the issue is... is new firmware arriving soon (I'm on latest already) , are there any known issues like this ?
I'm using zway purely as the controller, all automation is done from node-red and I never had issues like this with the UZB.
Re: still issues with the 7 Pro
Please update the firmware to the latest. Early SiLabs SDKs had issues with the reliability
vinisz
Post by vinisz »
I'm already on latest firmware
7.28?
vinisz
Post by vinisz »
Yes
Please share the log (part of it corresponding to a problematic moment) with a description of what happened at that moment (device X was turned on, device Y failed to turn on, ...) This will allow to check the reason.
vinisz
Post by vinisz »
Think I need to turn logging back on fist, what value should I set it ?
