Heatit - Z-Wave - ZM Thermostat 16A
otverber
Post by otverber »
Hello
Tried to include the Heatit - Z-Wave - ZM Thermostat 16A in my environment, however could not find it in the Select Device Description entry.
The element can be found in https://products.z-wavealliance.org/reg ... 0/products
Is there a way to update the local entities to be able to include the thermostate as intended?
Re: Heatit - Z-Wave - ZM Thermostat 16A
New devices from the Alliance database are not exported (due to the changed API access to the database). But this does not matter, as for new devices (including this HeatIt device) you don't need a Description file anymore.
