Zipato RFID Mini Keypad - how to set pin
login@huegli.co
Post by login@huegli.co »
Dear all
I have a very silly question. I have successfully added the Zipato RFID Mini Keypad Device to my Z-Wave.me system. I have also installed the app "Zipato RFID Keypad".
But how can I add/learn some PINs to the device? I only want to operate with PIN only. RFID tags are not needed.
If I enter some PINS in the app is tells me: "This field should have pattern ^([1-4]{4,10}|TAG USED)$ ".
How does the PIN learning process works for this device?
Any help would be appreciated.
Re: Zipato RFID Mini Keypad - how to set pin
according to the regex, you need to enter the pin (digits 1-4, from 4 to 10 chars)
login@huegli.co
Thx. After reinstalling the app it worked as expected.
thomas6987
Post by thomas6987 »
Overall nice, but unable to access more than most basic functions. Expert User Interface is not obviously accessible. The instructions for access don’t appear to work. Still checking it out. Update: I found a button to select Expert UI when I accessed find.Z-Wave.Me on Windows, in Settings > Devices > Manage with ExpertUI. For some reason, I couldn’t see that choice on my iPhone.
@thomas6987 Looks, like you used the wrong thread.
Anyway, Expert UI is not available in the mobile UI as it is not really designed for it. You can still access it from your phone's browser. You can also change the UI to enable this button in mobile mode too.
https://github.com/Z-Wave-Me/zwave-smar ... s.html#L23
In this like you see how to enable it in the mobile app too.
