ZUNO2 dynamic multichanel broken
calypso2k
Post by calypso2k »
hi,
ZUNO2 3.0.10 excluded several times, to be sure new config can be applied
this minimal example, taken from reference, does not work - interview stops on multichannel, device logs
53181INCOMING   SRC_ID:1.0 DST_ID:8192.0 KEY:1 OPTS:0 DATA:60 07
N_CH=1
**** Can't find channel for last cmd!
as this code is reference, can you provide me with a hint, what to change, so I can get working dynamic multichannel? Thank you.
#define MY_SERIAL    Serial
ZUNO_ENABLE(LOGGING_DBG LOGGING_UART=Serial WITH_CC_SWITCH_MULTILEVEL WITH_CC_BASIC)
byte dimmerValue = 99;
void setup() {
  MY_SERIAL.begin(115200);
  if(zunoStartDeviceConfiguration()) {
    zunoAddChannel(ZUNO_SWITCH_MULTILEVEL_CHANNEL_NUMBER, 0, 0);
    zunoSetZWChannel(0x0, 0x1 | ZWAVE_CHANNEL_MAPPED_BIT);
    zunoCommitCfg();//
  zunoAppendChannelHandler( 0,  1, CHANNEL_HANDLER_SINGLE_VALUEMAPPER, (void*)&dimmerValue);
  pinMode(LED_BUILTIN, OUTPUT);
void loop() {
  // put your main code here, to run repeatedly:
  digitalWrite(LED_BUILTIN, HIGH);
  delay(dimmerValue*10);
  digitalWrite(LED_BUILTIN, LOW);
Re: ZUNO2 dynamic multichanel broken
What is your controller?
The log from your controller is not very clear. Could you make it more verbose?
