Fibaro Flood Sensor FGFS-101 not reporting flood
select
Post by select »
Hi all,
I recently bought two Fibaro flood sensors (FGFS-101 ZW5 v3.4) and am failing to use them in my RaZberry Z-Wave.Me network.
The interviews went just fine without errors and temperature is reported frequently as excepted with both sensors.
However, the water / flood alarm is not handled correctly by the controller. When flooding them, the device beeps and flashes, but there is no event shown in the smart home UI.
I have no idea, how I can fix this issue. Your help would be greatly appreciated. Thanks a lot in advance!
RaZberry 7 Pro
Firmware version v4.0.2
UI version v1.14.2
Built date 22-12-2022 17:35:27
[2023-05-07 17:15:35.666] [D] [zway] SETDATA controller.data.APIVersion = "07.06"
[2023-05-07 17:15:35.666] [D] [zway] SETDATA controller.data.APIVersionMajor = 7 (0x00000007)
[2023-05-07 17:15:35.666] [D] [zway] SETDATA controller.data.APIVersionMinor = 6 (0x00000006)
[2023-05-07 17:15:35.666] [D] [zway] SETDATA controller.data.manufacturerId = 327 (0x00000147)
[2023-05-07 17:15:35.666] [D] [zway] SETDATA controller.data.manufacturerProductType = 1025 (0x00000401)
[2023-05-07 17:15:35.666] [D] [zway] SETDATA controller.data.manufacturerProductId = 257 (0x00000101)
[2023-05-07 17:15:35.669] [D] [zway] SETDATA controller.data.vendor = "RaZberry by Z-Wave.Me"
[2023-05-07 17:16:04.019] [D] [zway] RECEIVED: ( 01 16 00 04 00 1B 0D 60 0D 00 01 71 05 05 02 00 FF 05 02 00 B1 00 00 AD )
[2023-05-07 17:16:04.019] [D] [zway] SENT ACK
[2023-05-07 17:16:04.020] [D] [zway] SETDATA devices.27.data.lastReceived = 0 (0x00000000)
[2023-05-07 17:16:04.020] [E] [zway] Error returned from _zway_cc_call_handler(zway, device->default_instance, controller->id, 0, data[4 + L], &data[5 + L]): Function class not supported by the hardware (-4)
[2023-05-07 17:16:04.074] [D] [zway] RECEIVED: ( 01 0B 00 04 00 1B 02 98 40 B0 00 00 81 )
[2023-05-07 17:16:04.074] [D] [zway] SENT ACK
[2023-05-07 17:16:04.075] [D] [zway] SETDATA devices.27.data.lastReceived = 0 (0x00000000)
[2023-05-07 17:16:04.075] [I] [zway] Node 27:0 CC Security: sending Nonce Report
[2023-05-07 17:16:04.075] [I] [zway] Adding job: Nonce Report to node 27
[2023-05-07 17:16:04.075] [D] [zway] SENDING (cb 0x04): ( 01 11 00 13 1B 0A 98 80 7D BD A0 6F A3 F7 CC BA 05 04 D8 )
[2023-05-07 17:16:04.078] [D] [zway] RECEIVED ACK
[2023-05-07 17:16:04.079] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2023-05-07 17:16:04.079] [D] [zway] SENT ACK
[2023-05-07 17:16:04.079] [D] [zway] Delivered to Z-Wave stack
[2023-05-07 17:16:04.240] [D] [zway] RECEIVED: ( 01 1D 00 13 04 00 00 0F 01 B3 7F 7F 7F 7F 02 01 03 07 00 00 00 01 01 00 00 7F 7F 7F 7F 7F 30 )
[2023-05-07 17:16:04.240] [D] [zway] SENT ACK
[2023-05-07 17:16:04.240] [I] [zway] Job 0x13 (Nonce Report to node 27): Delivered
[2023-05-07 17:16:04.241] [D] [zway] SendData Response with callback 0x04 received: received by recipient
[2023-05-07 17:16:04.241] [D] [zway] SETDATA devices.27.data.lastSendInternal = **********
[2023-05-07 17:16:04.241] [D] [zway] SETDATA devices.27.data.lastSend = 2652 (0x00000a5c)
[2023-05-07 17:16:04.241] [D] [zway] Job 0x13 (Nonce Report to node 27): success
[2023-05-07 17:16:04.241] [I] [zway] Removing job: Nonce Report to node 27
[2023-05-07 17:16:04.402] [D] [zway] RECEIVED: ( 01 25 00 04 00 1B 1B 98 81 B7 19 B6 69 08 F4 AB 6D 56 3B F2 C0 1C DC 03 C1 7D B7 69 77 B5 E2 3C 5F A1 B3 00 01 28 0A )
[2023-05-07 17:16:04.403] [D] [zway] SENT ACK
[2023-05-07 17:16:04.403] [D] [zway] SETDATA devices.27.data.lastReceived = 0 (0x00000000)
[2023-05-07 17:16:04.403] [I] [zway] Node 27:0 CC Security: Received a secure message
[2023-05-07 17:16:04.403] [D] [zway] SETDATA devices.27.instances.0.commandClasses.152.data.firstPart = **********
[2023-05-07 17:16:04.403] [I] [zway] Node 27:0 CC Security: passing decrypted packet to application level: [ 60 0d 00 02 20 01 ff ]
[2023-05-07 17:16:04.403] [E] [zway] Error returned from _zway_cc_call_handler(zway, device->default_instance, controller->id, 0, data[4 + L], &data[5 + L]): Function class not supported by the hardware (-4)
[2023-05-07 17:16:04.563] [D] [zway] RECEIVED: ( 01 0D 00 04 00 1B 02 98 40 B3 00 02 0F 01 88 )
[2023-05-07 17:16:04.563] [D] [zway] SENT ACK
[2023-05-07 17:16:04.563] [D] [zway] SETDATA devices.27.data.lastReceived = 0 (0x00000000)
[2023-05-07 17:16:04.563] [I] [zway] Node 27:0 CC Security: sending Nonce Report
[2023-05-07 17:16:04.563] [I] [zway] Adding job: Nonce Report to node 27
[2023-05-07 17:16:04.564] [D] [zway] SENDING (cb 0x05): ( 01 11 00 13 1B 0A 98 80 13 EE 85 D2 1E 1D 2E 96 05 05 E5 )
[2023-05-07 17:16:04.566] [D] [zway] RECEIVED ACK
[2023-05-07 17:16:04.568] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2023-05-07 17:16:04.568] [D] [zway] SENT ACK
[2023-05-07 17:16:04.568] [D] [zway] Delivered to Z-Wave stack
[2023-05-07 17:16:04.835] [D] [zway] RECEIVED: ( 01 1D 00 13 05 00 00 1A 01 B2 7F 7F 7F 7F 02 01 03 07 00 00 00 01 01 00 00 7F 7F 7F 7F 7F 25 )
[2023-05-07 17:16:04.836] [D] [zway] SENT ACK
[2023-05-07 17:16:04.836] [I] [zway] Job 0x13 (Nonce Report to node 27): Delivered
[2023-05-07 17:16:04.836] [D] [zway] SendData Response with callback 0x05 received: received by recipient
[2023-05-07 17:16:04.836] [D] [zway] SETDATA devices.27.data.lastSendInternal = **********
[2023-05-07 17:16:04.836] [D] [zway] SETDATA devices.27.data.lastSend = 2708 (0x00000a94)
[2023-05-07 17:16:04.836] [D] [zway] Job 0x13 (Nonce Report to node 27): success
[2023-05-07 17:16:04.836] [I] [zway] Removing job: Nonce Report to node 27
[2023-05-07 17:16:05.013] [D] [zway] RECEIVED: ( 01 2D 00 04 00 1B 21 98 81 CB B7 9F 3E 3C CC 43 96 FD E5 AF CB 40 91 F9 C0 47 8E C6 73 4B DD 13 4C 4F 52 52 87 97 58 E3 B3 00 03 2E 01 00 57 )
[2023-05-07 17:16:05.013] [D] [zway] SENT ACK
[2023-05-07 17:16:05.013] [D] [zway] SETDATA devices.27.data.lastReceived = 0 (0x00000000)
[2023-05-07 17:16:05.014] [I] [zway] Node 27:0 CC Security: Received a secure message
[2023-05-07 17:16:05.014] [D] [zway] SETDATA devices.27.instances.0.commandClasses.152.data.firstPart = **********
[2023-05-07 17:16:05.014] [I] [zway] Node 27:0 CC Security: passing decrypted packet to application level: [ 60 0d 00 03 71 05 05 02 00 ff 05 02 00 ]
[2023-05-07 17:16:05.014] [E] [zway] Error returned from _zway_cc_call_handler(zway, device->default_instance, controller->id, 0, data[4 + L], &data[5 + L]): Function class not supported by the hardware (-4)
Re: Fibaro Flood Sensor FGFS-101 not reporting flood
Please remove the association to 1.1 and set a plain association or to 1.0 (not sure the latter is supported by the device). As another option, you can change in Defaults.xml the number of channels from 0 to 1 (or more) and restart Z-Way.
