Hello
Trying to make MxMQTT subscriber to get figures from the broker after a disastrous update.
Display Current MQTT Connection State
for Create virtual device
you typicaly need to give Device Title and indicate Icon
I dont remember what to write in the Icon field, hence nothing works ; cant save changes
please help
Had this working like champ prior to latest update..
I guess the MxBasemodule Library isnt properly installed?
> Copy the app folder on the server computer to userModules folder. how do I make this on a raspi with mosquitto running?
MxMQTT Subscriber Icon path or?
Re: MxMQTT Subscriber Icon path or?
I hope it wasn't an update of MxMQTT Subscriber or MxBasemodule Library.Trying to make MxMQTT subscriber to get figures from the broker after a disastrous update.
Do you use the latest update of MxMQTT subscriber V1.2.6?
I thought the text is clear:you typicaly need to give Device Title and indicate Icon. I dont remember what to write in the Icon field, hence nothing works ; cant save changes
- Without path and without extension: standard zway icon.
For example: alarm, temperature, ...
- Without path but with extension: local icon from htdocs folder (not hfdocs, there's a write error).
For example icon.png or any other icon you put to the local htdocs folder.
- With path and with extension: icon from different location.
Insert whatever you want, <path>/<file>.<png, even a URL.
In this case simply use the presetting: icon.png.
Additional hint: some things cannot be changed after once it's stored, like this icon.
Workaround: disable the instance, duplicate it, change the value and save the new instance.
Install MxBasemodule in the same manner as all other modules:I guess the MxBasemodule Library isnt properly installed?
- download from store (V3.8.1)
- if it isn't installed: add app + store
- or if it is already installed: open and store again, if you think there's a problem with it
This text is very old and obsolete. download the latest version.Copy the app folder on the server computer to userModules folder
RaZberry by Z-Wave.Me ZW0700 7.20.00 07.38/1766938484 1025/257
Base model is 3.8.1 ; the shell script “automation/userModules/MxBaseModule/sh/execShell.bash” to put in .syscommands, Is this necessary ?
I'm on 4.1.0 and have had some issues with the upgrade.
Is the latest Mxmodules tested on 4.1.0 ?
I'm evaluating reverting to 4.0.3 instead of trying to make things work on 4.1.0 , but if its supposed to work I'll give it a try
Hardware
Vendor: RaZberry by Z-Wave.Me
Vendors Product ID: 1024 / 2
Z-Wave Chip: ZW0500
Firmware
SDK Version: 6.82.01
Serial API Version: 05.39
Software Information
Version number: v4.1.0-23-g89a32d68
Hardware
Z-Wave Chip: ZW0500
Firmware
The entry in .syscommands is not necessary for MxMQTT Subsciber. It doesn't use this function.Base model is 3.8.1 ; the shell script “automation/userModules/MxBaseModule/sh/execShell.bash” to put in .syscommands, Is this necessary ?
I've upgraded to 4.1.0 at 19.6.23. Everything is running since that time without problems.Is the latest Mxmodules tested on 4.1.0
Back on 4.0.3 and MxMQTT Subscriber works like before; without the shellscript in .syscommands
goodbye 4.1.0
thanks a lot !
goodbye 4.1.0
thanks a lot !
I'm glad to hear that.
Your case is a good example of the importance of documenting the parameters.
The MxInfo2 Tool Collection provides a convenient way to do this.
The InstanceCompare item allows you to create documentation for all your modules. Use Print to PDF.
Install it from app store.
Hello
I hope you are more successful than me with the 4.1.0
Need a tip regarding an app for calculating the relation between two subscriber element > to create a new element
"Price Now" / "Price Max" > gives a number less than or equal to 1 [Energy Cost Level]
A virtual element "Energy cost High" is switched ON when "Energy Cost Level" is higher than .98 or whatever.
Mathematica gives a number for "Price Now" / "Price Max" when Units are set to NOK !!!
magic ...
magic ...
