Fluid pressure sensor
markchang
Post by markchang »
I want to manage a fluid circuit controlling its pressure.
After some searches, I don’t find pressure sensors with z wave capabilities.
Anyone knows if they exist or is possible to build one easily?
Regards,
J
lanbrown
Re: Fluid pressure sensor
Post by lanbrown »
Z-Uno 2 board with the appropriate sensor(s) and controls?
markchang
Post by markchang »
I don’t find pressure sensor for fluids, this is the problem.
I know that it is possible to use a regular pressure sensor, know its calibration and then use resistance to use it as a pressure signal but… I want something made, plug and play in fluid line 🙈
michap
Post by michap »
You think about something like this?
https://www.aliexpress.com/i/33028576390.html
You can find it also in local stores...
The analog output you can connect to Z-Uno.
Michael
markchang
Post by markchang »
Yes, something like that but made, I mean, sensor + plate plug and play
lanbrown
Post by lanbrown »
That is a very limited use case. If a company did decide to make something like that, you wouldn't like the price because of the low volume means high price to sell at to recover their costs.
michap
Post by michap »
lanbrown wrote:
19 Dec 2023 20:32
Right.
I would take a Z-UnoG2 and this sensor and make it myself. It is really not hard to do.
The "hardest" work is to find/make/print a case for the sensor ;)
Michael
markchang
Post by markchang »
In ma case, The box designed and printed will not be The problem :-)
I understand your arguments. Bad news for me 😩
lanbrown
Post by lanbrown »
The other advantage of the Z-Uno G2 is that it will support the latest Z-Wave specifications and down the road, if a new Z-Wave specification is released, you can port the sensor and most if not all of the code over to say a Z-Uno G3.
I would also think the limited use case for what you're looking for, support and firmware updates might be non-existent.
Steve_Elves
Post by Steve_Elves »
Depending on the pressure range you wish to measure, there are a number of devices available that provide a 0.5V - 4.5 VDC analog signal for water pressure. I found a couple from DigiKey: a) Seeed Technology part number 1597-1515-ND for about $20 CDN that will measure 0-1200 kPa, and b) Honeywell Sensor part number MIPAN2XX100PSAAX for about $110 that will measure 0-2400 kPa. I'm using a similar one to monitor the pressure from my well water system; it's totally reliable. I was able to write a small sketch that reports the pressure every couple of minutes - dead easy. The Z-Uno can measure an analog input in that voltage range with no difficulty. Took a bit of fiddling to calibrate properly against a verified gauge, but has been rock steady since.
I first tried a cheapo sensor from Aliexpress in China. Was advertised that it would measure water pressure, but the sensing element wasn't waterproof and it corroded and failed within a couple of weeks. Would be useful for petrol or oil, I guess, but not for water. Buy a better one from a reputable dealer.
