Configuration parameters in 3.0.12 beta
aleconakad
Post by aleconakad »
I am currently giving 3.0.12b a try. I have sketch file called eol.ino that stores some stuff in EEPROM and sets the default values for the parameters I use in my main sketch. For some reason, when I use zunoSaveCFGParam() function, no values are getting written to EEPROM. On 3.0.10 it works flawlessly. The only possibility to have default values for parameters saved is to use the macro ZUNO_SETUP_CONFIGPARAMETERS.
But I am wondering if ZUNO_SETUP_CONFIGPARAMETERS is the correct way to proceed. Each time I flash or update my sketch, the parameters will be overwritten. I don't think this is the intended usage for the default value in this macro. Im my opinion, the macro should check for a default written value for a config parameter in EEPROM in production (let's say 0xAFAFAFAF), and only write the default value provided by the macro ZUNO_SETUP_CONFIGPARAMETERS when the config parameter hasn't been set before.
Is this issue known to you?
amatilda
Re: Configuration parameters in 3.0.12 beta
Post by amatilda »
aleconakad wrote:
06 Mar 2024 15:43
Hello. Can you give an example of using zunoSaveCFGParam?
amatilda
Post by amatilda »
aleconakad wrote:
06 Mar 2024 15:43
At the moment this functionality is not supported.
aleconakad
Here's a snapshot:
#ifdef FLASH_CONFIG_PARAMS
void flash_config_params() {
  Serial.println("Flashing Z-UNO sketch default configuration parameters");
  val = 0;    // fading algorithm
  zunoSaveCFGParam(64, val);
  delay(50);
  val = 3000;    // fading time
  zunoSaveCFGParam(65, val);
  delay(50);
  val = 0;    // operation mode
  zunoSaveCFGParam(66, val);
  delay(50);
  val = 99;    // dimming max
  zunoSaveCFGParam(67, val);
  delay(50);
  val = 1;    // dimming min
  zunoSaveCFGParam(68, val);
  delay(50);
  val = 1;    // start state
  zunoSaveCFGParam(69, val);
  delay(50);
  val = 0;    // strip type
  zunoSaveCFGParam(70, val);
  delay(50);
  val = 0;    // white generation
  zunoSaveCFGParam(71, val);
  delay(50);
  val = 15;    // power report components
  zunoSaveCFGParam(72, val);
  delay(50);
  val = 0;     // report frequency
  zunoSaveCFGParam(73, val);
  delay(50);
  val = 25;   // report on change in %
  zunoSaveCFGParam(74, val);
  delay(50);
  val = 0;    // switch multilevel
  zunoSaveCFGParam(75, val);
  delay(50);
  val = 0;    // set animation
  zunoSaveCFGParam(76, val);
  delay(50);
  val = 0;     // on mode change
  zunoSaveCFGParam(77, val);
  delay(50);
  val = 0;    // start delay in seconds
  zunoSaveCFGParam(78, val);
  delay(50);
  val = 100;    // extension factor
  zunoSaveCFGParam(79, val);
  delay(50);
  val = 0;    // high priority notifications
  zunoSaveCFGParam(80, val);
  delay(50);
  val = 0;    // low priority notifications
  zunoSaveCFGParam(81, val);
  delay(500);
  Serial.println("Flashing of Z-UNO sketch default configuration parameters completed!");
#define PARAM_START_ADDR    64
#define PARAM_END_ADDR      81
void verify_flash_config_params() {
  Serial.println("Verifying Z-UNO sketch default configuration parameters");
  byte i;
  for (i = PARAM_START_ADDR; i <= PARAM_END_ADDR; i++) {
    val = zunoLoadCFGParam(i);
    Serial.print("Param ");
    Serial.print(i);
    Serial.print(": ");
    Serial.println(val);
    delay(100);
  delay(200);
  Serial.println("Verification of Z-UNO sketch default configuration parameters completed!");
#endif
This writes the cfg parameters, then read them out and print them on the serial console. In 3.0.10 and older it works flawlessly. In 3.0.12b it doesn't work.
Instead I have to use:
#ifdef STATIC_CONFIG_PARAMS
// Device's configuration parametrs definitions
ZUNO_SETUP_CONFIGPARAMETERS(
        ZUNO_CONFIG_PARAMETER_1B("Fading algorithm", 0, 1, 0),
        ZUNO_CONFIG_PARAMETER_2B("Fading time", 0, 10000, 3000),
        ZUNO_CONFIG_PARAMETER_1B("Operating mode", 0, 2, 0),
        ZUNO_CONFIG_PARAMETER_1B("Dimming max", 1, 99, 99),
        ZUNO_CONFIG_PARAMETER_1B("Dimming min", 1, 99, 1),
        ZUNO_CONFIG_PARAMETER_1B("State on start", 0, 2, 1),
        ZUNO_CONFIG_PARAMETER_1B("RGBW Strip type", 0, 2, 1),
        ZUNO_CONFIG_PARAMETER_1B("White color generation", 0, 1, 0),
        ZUNO_CONFIG_PARAMETER_1B("Power report", 0, 0x0F, 0x0F),
        ZUNO_CONFIG_PARAMETER_2B("Power report frequency", 0, 65535, 0),
        ZUNO_CONFIG_PARAMETER_1B("Power report on change", 0, 100, 25),
        ZUNO_CONFIG_PARAMETER_1B("Handling of 0xFF switch multilevel value", 0, 1, 0),
        ZUNO_CONFIG_PARAMETER_1B("Set animation", 0, 13, 0),
        ZUNO_CONFIG_PARAMETER_1B("On mode change", 0, 2, 0),
        ZUNO_CONFIG_PARAMETER_2B("Start delay (in sec)", 0, 600, 0),
        ZUNO_CONFIG_PARAMETER_2B("Strip extension factor", 100, 65536, 100),
        ZUNO_CONFIG_PARAMETER_2B("Animations on high priority notifications", 0, 0xFFFF, 0x0000),
#endif
Furthermore, any change to these parameters from the controller will not lead to any effective change on Z-Uno2.
amatilda
Post by amatilda »
aleconakad wrote:
12 Mar 2024 12:48
I checked everything is changing successfully.
Maybe you are using numbers out of bounds?
As an example here:
The correct numbers are 0 and 1 - all others cannot be used.
amatilda
Post by amatilda »
aleconakad wrote:
12 Mar 2024 12:48
I'm not sure I understood exactly. But if you need to use ZUNO_SETUP_CONFIGPARAMETERS, and not through zunoSaveCFGParam - then this is how it should be - so that the command class has all the necessary information for its work.
aleconakad
After a while of digging it turned out that my usb cable had some issue. Replacing it simply fixed the problem. BTW I use Visual Studio Code on a M2 Apple Silicon. My initial thoughts lead me to try out the same sketch on multiple machines, including Linux and windows in a virtualized environment. All were exhibiting the same symptom. When I replaced the cable, issue was just gone.
Thanks for your support.
