hi all,
so i am currently am having the following issues
I am running Arduino ide 1.8.19, I believe I have a first gen zuno as it looks like this
When I try to burn bootloader in Arduino I get this error
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Z-Wave>ME Z-Uno, Russian, Disabled, Disabled, Disabled"
Openning port .............................. OK
Closing port .............................. OK
ERROR: It's not ZUNO G1 connected to port:COM3.
[ *] ..............................Error while burning bootloader.
Syncing with Z-Uno .............................. FAILED
Error 0 Can't sync with Z-Uno bootloader. It doesn't respond!
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
So then I try to do it using the gen 2 standards
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Z-Wave>ME Z-Uno2, Russian, Normal +0dBm, Disabled, Disabled, Enabled"
*** ZME Z-UNO G2 preprocessor. Platform:Windows Version:0.40b1 ***
BOOTLOADER
Error 1 Can't request board information! ErrCode=-1
If I run the recommended 1.6.5 for gen 1 I get this
Arduino: 1.6.5 (Windows 8.1), Board: "Z-Wave>ME Z-Uno, Russian, Disabled, Disabled, Disabled"
enabled in File > Preferences.
And again this is with gen 2 standards
Arduino: 1.6.5 (Windows 8.1), Board: "Z-Wave>ME Z-Uno2, Russian, Normal +0dBm, Disabled, Disabled, Enabled"
BOOTLOADER
Syncing with Z-Uno ('RST' btn?) [ * ] ..............................
Syncing with Z-Uno ('RST' btn?) [ *] ..............................
Syncing with Z-Uno ('RST' btn?) [* ] ..............................
Syncing with Z-Uno ('RST' btn?) [ *] ..............................Error while burning bootloader.
I have also tried hitting the reset button during, 2 different boards as I have 4, there are no issues in device manager and I have also tried a few different usb cable
Is there anything I am missing?
issue with bootloader z-uno
Re: issue with bootloader z-uno
Try to hold the BTN and short press reset. This will go in rescue mode.
yeah no luck, it flashed red then went back to flashing green, even when i tried to do it while doing bootloader
do i have to flash bootloader back onto it?
Please try to burn the bootloader.
Ok I'll look up how to do that, unless you have a forum link handy
