TimeParameter command class don't show up in ExpertUI
KGBEl
Post by KGBEl »
Hi, earlier I have been able to update the internal clock in my Z-Uno (ver 2), via TimeParameter command class.
For som unknown reason I changed frequence to RU and lost contact with Z-Uno.
So I removed it via "Failed node" before I noticed the frequence fault.
Then I excluded Z-Uno it from network and included it again.
Now in expert UI there is no TimeParameter command class showing.
It's 3.0.12 running.
What have I done wrong?
Re: TimeParameter command class don't show up in ExpertUI
Sure it us not in rescue mode? Is your sketch still running?
KGBEl
Post by KGBEl »
Yes it is running.
How do I know if it's in rescue mode?
KGBEl
Post by KGBEl »
If rescue mode changes to normal state after reset, it is in normal state.
KGBEl
Post by KGBEl »
Hi again.
I have excluded and included again, no difference, still no TimeParameter command class.
What is wrong?
