and a function to combine entity's
seiken
Post by seiken »
hi
i like i funktion so dimmers dont get both a switch and a dimmer,
the problem for me i now if i turn off using the dimmer funktion, then press on the wall switch to turn on the light, the light turns on at 0 så then i have to DoubleClick and hold the button to get light. turning off on the switch works but i cant dimm using the switch.
so i like it to be a entity that is a switch when clicking on it and dimmer when hålding it in as on other controllers
lanbrown
Re: and a function to combine entity's
Post by lanbrown »
You can click the gear icon and hide that particular element. So you won't see it in the GUI, but it still exists.
