How to activate Longe Range
Hello, I have a Razberry 7 Pro with Long Range Support. Under Expert UI->Network->Controller Info->Capabilities, Z-Wave Long Range Support is also displayed, but under Expert UI->Network->Control it still says ‘Long Range is not supported or not enabled in your hardware’. How can I activate Long Range support?
Raspi 4 - (bullseye) Zwave Version 3.2.3 Raz 7 Pro, Serial API Version: 07.13
Re: How to activate Longe Range
First you need to be in the US. It is not available in other regions as of yet.
Next, expert UI -> Controller info and look for get more options near the bottom. There you can get an updated license which would have long-range support added.
You also need to switch to US LR frequency
