Fibaro heat controller / thermostat FGT-001
phigu
Post by phigu »
I'm new to this forum. I've been using RaZberry with Z-Wave for a couple of weeks now and it works great. So far this forum has provided all the answers I needed to get my problems solved. Unfortunately, I couldn't find any hints to my current problem.
I managed to include quite a few devices in my Network but now I'm struggling to get my new Fibaro Heat Controller FGT-001 working. The Interview always completes most of the command classes. Nevertheless, the CommandClass "Security" in instance 1 and 2 won't complete. Resetting the device to factory defaults didn't help. Does anyone have a solution to this issue?
phigu
Re: Fibaro heat controller / thermostat FGT-001
Post by phigu »
The log says:
Node 30:1 CC Security: secure channel not established on root device - can not interview inside channel
IgoriokLT
Post by IgoriokLT »
Try to make Insecure Inclusion. Works most of the times with Fibaro devices
phigu
Post by phigu »
I've tried secure and insecure inclusion multiple times. Both didn't finish completely.
pssara
Post by pssara »
I have the same problem. Anyone solved it?
aivs
Post by aivs »
Try to update to 3.0.0.
After adding device wait for the window to appear. Enter pin code. Device should be added with security s2.
Arek
Post by Arek »
try to be closer to razzbery (max 2m) with fibaro device during inclusion. In ma case it helps.
Preetisharma
Contact:
Post by Preetisharma »
Excellent thread! Thank you!
