No access to IP:8083 page
testerbb
Post by testerbb » 04 May 2018 21:29
Hi everybody
I'm new here, because i started to play around with my raspberry and the option of zwave is very interesting.
Nevertheless, i followed the installation procedure, all works fine.
By accessing the page https://find.z-wave.me/zboxweb the link with the IP is visible, ok.
By clicking and going to the page: IP:8083 an error message is displayed: unable to connect. It seems the server is not running, but it does. Checked with z-way server status. even with localhost:8083 the same error is shown.
Do i have to configure my router or where could be the error?
Thanks in advance for your help
adamjarema
Re: No access to IP:8083 page
Post by adamjarema » 05 May 2018 05:25
Can you check any log pages? I'm having this issue too. What I am finding is that the z-way server process is not actually starting. If you look at: systemctl status z-way-server it should tell you if it is running or has exited.
testerbb
Post by testerbb » 05 May 2018 10:12
In my eyes its running.. isn't it?
pi@raspberrypi:~ $ systemctl status z-way-server
● z-way-server.service - LSB: RaZberry Z-Wave service
Loaded: loaded (/etc/init.d/z-way-server; generated; vendor preset: enabled)
Active: active (exited) since Wed 2018-05-02 21:00:38 CEST; 2 days ago
Docs: man:systemd-sysv-generator(8)
Process: 318 ExecStart=/etc/init.d/z-way-server start (code=exited, status=0/S
CGroup: /system.slice/z-way-server.service
May 02 21:00:38 raspberrypi systemd[1]: Starting LSB: RaZberry Z-Wave service...
May 02 21:00:38 raspberrypi z-way-server[318]: Starting z-way-server: done.
May 02 21:00:38 raspberrypi systemd[1]: Started LSB: RaZberry Z-Wave service.
adamjarema
Post by adamjarema » 08 May 2018 06:15
No, it has exited. Seems you and I have the same problem. Interesting.
Brekne
Post by Brekne » 09 May 2018 19:33
Backend server error. When will this problem be solved. Have no remote access to my 2 razberries. Frustrated
testerbb
Post by testerbb » 09 May 2018 21:34
Does anybody have any ideas to solve the problem?
adamjarema
Post by adamjarema » 11 May 2018 03:05
My problem with this is that I'm not getting any logs from the z-way server. I think it has something to do with one of the packages being updated that the server depends on, but that's just a hunch.
mtylerb
Post by mtylerb » 07 Jun 2018 10:09
I know it's been almost a month, but I thought you might be interested in the solution I found with the help of the github issues. I'm copying this directly from the Raspbian forum where I had previously asked for help:
Well, answered my own question after having a eureka "search idea" moment. I found a github issue with a specific response that seems to have solve the problem. So for others:
$ cd \tmp
$ wget http://mirrordirector.raspbian.org/raspbian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb
$ sudo dpkg -x libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb .
$ sudo mv usr/lib/arm-linux-gnueabihf/lib* /opt/z-way-server/libs/
Please keep in mind that the filename had changed from the original response in the github issue. I had to traverse the URL directories to discover that libssl1.0.0_1.0.1t-1+deb8u7_armhf.deb had become libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb. So if you get a 404 error with the wget command, you may need to do something similar. The problem occurs due to the change in libssl from 1.0.0 to 1.0.2, so you're looking specifically for libssl1.0.0.
With that in, my problem seems to be solved for the moment. They're planning on updating to stretch, but they seem to be on the slower side. At least it runs.
DJay
Post by DJay » 21 Jun 2018 18:53
@mtylerb Thanks a lot for your input on this.
I was facing a similar problem I think. And your post was helpful.
Unfortunately I'm still not getting all to work and would appreciate your help. Sorry for maybe asking stupid questions. I'm not a pro on z-wave, raspberry.
I had z-wave me with the Z-Wave Me RaZberry Modul running on a Pi 2 for almost a year. Everything was working well.
Now I moved to a Pi 3 B+. I did a factory reset on the z-wave me on the Pi 2 and plunged the model into the new Pi 3.
I installed the software using
sudo wget -q -O - razberry.z-wave.me/install/v2.3.7 | sudo bash
OK:1 http://linux.teamviewer.com/deb stable InRelease
OK:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
OK:3 http://archive.raspberrypi.org/debian stretch InRelease
OK:4 http://linux.teamviewer.com/deb preview InRelease
After this I already noticed something in the log that didn't look right.
File or Folder not found.
cp: der Aufruf von stat für '/opt/z-way-server_2018-06-21-12-56-37/config/Configuration.xml' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
Stopping mongoose http server
[ ok ] Stopping mongoose (via systemctl): mongoose.service.
Adding mongoose to autostart
Start mongoose http server
[ ok ] Starting mongoose (via systemctl): mongoose.service.
ls: Zugriff auf 'config/zddx/*.xml' nicht möglich: Datei oder Verzeichnis nicht gefunden
Usage: ./z-cfg-update <filename>
rm: das Entfernen von '/tmp/zway_install_inittab' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
Thank you for using RaZberry!
I was not able to login to the direct connect to Z-Way by the local IP:8083
This sounded similar to what I was reading in this post I would assume?
So I tried your workaround
$ cd \tmp
After rebooting the Pi I was at least able to reach the local IP and direct connect to Z-Way.
But now its not possible to add a device or Manage with ExpertUI. I always get an Error
SmartHome UI - ERROR Unable to load data
I would very much appreciate your help or of course anybody others help to get this to work.
Thanks in advance.
