Razberry 7 Pro Issues
micky1500
Re: Razberry 7 Pro Issues
Post by micky1500 »
Do you feel lucky ?
4.0.0.2 is available.
Seem to have jumped a big gap from 3.2.2
https://razberry.z-wave.me/z-way-server ... _armhf.deb
You can test the z-way-3.2.2-124-g90cdf33f_armhf.deb which is the next release. It includes a lot of certification improvements and many fixes.
v4.0.0-2 is the beta with Long Rage support - same as v3.2.2-124, but with Long Range.
harre
Post by harre »
I had some major issues before updating to the latest firmware.
I however still had some issues with my fibaro dimmer 2 devices.
https://manuals.fibaro.com/dimmer-2/
I tried to exclude and then include it again but I'm unable to get it to pair using S2/S0, it just reverts to get just unsecure pairing.
I just get this message on the expert interface:
" Security S2 timeout. No Security Channel established"
I have another question too, if I do a "force interview" it seems the security is invalidated and the only way to recover is to exclude and include again, is there a way to get it back to secure again?
Security can only be done right after the inclusion. After. That the device will never accept security keys. This is for security to make sure a vilain can not "encrypt" all your devices and ask for money to decrypt ;)
Please check the log to see why the security channel was not established
harre
Post by harre »
Here's the logs.
The old device where is working perfectly is on a rpi3 board using razberry2 generation 5 card.
https://www.dropbox.com/s/jpdcqxr6jg79r ... 5.log?dl=0
The new device is on a rpi4 using the Razberry 7 pro.
https://www.dropbox.com/s/fphzcx61bovjo ... 7.log?dl=0
The old device had z-way 3.2.2 but I tried to use the 4.0.0-2-gba4062cf-lws16 too but with same issue.
harre
Post by harre »
Do you find anything suspicious in the logs?
Device #13 was re-included without excluding/resetting it priorly. Please reset or exclude it then add again
harre
Post by harre »
I tried excluding and including multiple times without any difference.
Is there something else I can try?
I'm suspecting there's something in the initial handshake with the fibaro dimmer 2 that fails as other devices works properly to include securely.
Please show the log with exclusion and inclusion
z-wavettaja
Post by z-wavettaja »
I updated fw from 3.2.2 to 3.2.3 and now I'm in more trouble than before.
In 3.2.2 scenes were unusable, because only one device coud be operated at time.
But now after update almost nothing works anymore.
I attach a sequence from /var/log/z-way-server.log. I tried to switch socked to off (id 5). Same with others, not working and this kind of messages appears in log.
I don't understand what's the problem and how to fix it?
[2022-04-07 18:27:37.084] [D] [zway] Wrong checksum
[2022-04-07 18:27:37.084] [D] [zway] SENT NAK
[2022-04-07 18:27:37.310] [D] [zway] RECEIVED: ( 01 10 00 0A 07 00 03 02 07 06 5E 98 9F 6C 56 55 00 D4 )
[2022-04-07 18:27:37.310] [D] [zway] SENT ACK
[2022-04-07 18:27:37.311] [W] [zway] No job of class 0x0a is waiting for callback 0x07
[2022-04-07 18:27:37.311] [I] [zway] Unhandled callback for function 0x00
[2022-04-07 18:27:37.311] [I] [zway] Removing job: Unknown function class
[2022-04-07 18:27:37.327] [D] [zway] RECEIVED: ( 01 13 00 04 00 04 0A 98 80 84 E6 66 10 D2 9B 14 8D B9 00 00 83 )
[2022-04-07 18:27:37.327] [D] [zway] SENT ACK
[2022-04-07 18:27:37.327] [W] [zway] Discarding duplicate packet from node 4
[2022-04-07 18:27:37.379] [D] [zway] Job 0x13: deleted from queue
[2022-04-07 18:27:37.931] [I] [zway] Job 0x13 (Security, SwitchBinary Set to node 4): Job not sent before timeout
[2022-04-07 18:27:37.931] [I] [zway] Job 0x13 (Security, SwitchBinary Set to node 4): Cancelling job: Security, SwitchBinary Set to node  to node 4
[2022-04-07 18:27:37.931] [I] [zway] Job 0x13 (SwitchBinary Set to node 4): Cancelling job: SwitchBinary Set to node  to node 4
[2022-04-07 18:27:37.931] [I] [zway] Removing job: SwitchBinary Set to node 4
[2022-04-07 18:27:37.931] [I] [zway] Removing job: Security, SwitchBinary Set to node 4
[2022-04-07 18:27:48.721] [I] [core] [Astronomy] Calculate
[2022-04-07 18:27:48.760] [I] [core] Notification: device-info (device-status): {"dev":"Solar altitude","l":"12.83 °","location":0}
[2022-04-07 18:27:48.788] [I] [core] Notification: device-info (device-status): {"dev":"Solar azimuth","l":"261.24 °","location":0}
[2022-04-07 18:27:48.819] [I] [core] [BaseModule-13] Set lastLevel to 12.83 for Astronomy_17_altitude (was 12.95)
[2022-04-07 18:27:48.821] [I] [core] [BaseModule-13] Set lastLevel to 261.24 for Astronomy_17_azimuth (was 261.02)
[2022-04-07 18:27:49.973] [I] [zway] Adding job: Get background noise level
[2022-04-07 18:27:53.337] [I] [core] ---  ZWayVDev_zway_5-0-37 performCommand processing: {"0":"off","1":{}}
[2022-04-07 18:27:53.338] [I] [zway] Using security scheme S0
[2022-04-07 18:27:53.338] [I] [zway] Adding job: SwitchBinary Set to node 5
[2022-04-07 18:27:53.338] [I] [zway] Adding job: SwitchBinary Get to node 5
[2022-04-07 18:27:55.445] [D] [zway] Job 0x13: deleted from queue
[2022-04-07 18:27:55.445] [D] [zway] Job 0x16: deleted from queue
[2022-04-07 18:27:55.456] [D] [zway] Job 0x62: deleted from queue
[2022-04-07 18:27:55.517] [D] [zway] Job 0x3b: deleted from queue
[2022-04-07 18:27:55.517] [I] [zway] Job 0x13 (Nonce Get to node 61): No callback received before timeout
[2022-04-07 18:27:55.517] [I] [zway] Job 0x13 (Nonce Get to node 61): Cancelling
[2022-04-07 18:27:55.517] [I] [zway] Adding job: Abort data send
[2022-04-07 18:27:55.517] [D] [zway] SENDING: ( 01 03 00 16 EA )
[2022-04-07 18:27:55.519] [D] [zway] RECEIVED ACK
[2022-04-07 18:27:55.519] [I] [zway] Removing job: Abort data send
[2022-04-07 18:27:55.529] [I] [zway] Node 5:0 CC Security: sending Nonce Get
[2022-04-07 18:27:55.529] [D] [zway] SETDATA devices.5.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2022-04-07 18:27:55.529] [I] [zway] Adding job: Nonce Get to node 5
[2022-04-07 18:27:55.529] [D] [zway] SETDATA devices.5.data.lastNonceGet = 377040 (0x0005c0d0)
[2022-04-07 18:27:55.529] [D] [zway] SENDING (cb 0x4f): ( 01 09 00 13 3D 02 98 40 25 4F 68 )
[2022-04-07 18:27:55.531] [D] [zway] RECEIVED ACK
[2022-04-07 18:27:55.533] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-04-07 18:27:55.533] [D] [zway] SENT ACK
[2022-04-07 18:27:55.533] [D] [zway] Delivered to Z-Wave stack
[2022-04-07 18:27:57.375] [D] [zway] RECEIVED: ( 01 35 01 F8 08 02 01 11 07 05 00 00 00 00 00 00 00 00 38 ED 00 E0 00 00 00 00 01 01 01 01 FF FF 00 00 B0 1C 00 20 18 00 00 00 2D 9B 00 00 2C 9B 00 00 00 00 00 61 FF )
[2022-04-07 18:27:57.375] [D] [zway] Wrong checksum
[2022-04-07 18:27:57.375] [D] [zway] SENT NAK
[2022-04-07 18:27:57.602] [D] [zway] RECEIVED: ( 01 10 00 0A 07 00 03 02 07 06 5E 98 9F 6C 56 55 00 D4 )
[2022-04-07 18:27:57.602] [D] [zway] SENT ACK
[2022-04-07 18:27:57.602] [W] [zway] No job of class 0x0a is waiting for callback 0x07
[2022-04-07 18:27:57.602] [I] [zway] Unhandled callback for function 0x00
[2022-04-07 18:27:57.602] [I] [zway] Removing job: Unknown function class
[2022-04-07 18:27:58.184] [D] [zway] Job 0x13: deleted from queue
[2022-04-07 18:28:15.774] [D] [zway] Job 0x16: deleted from queue
[2022-04-07 18:28:15.784] [I] [zway] Job 0x13 (Nonce Get to node 61): No callback received before timeout
[2022-04-07 18:28:15.784] [I] [zway] Job 0x13 (Nonce Get to node 61): Cancelling
[2022-04-07 18:28:15.784] [I] [zway] Adding job: Abort data send
[2022-04-07 18:28:15.785] [D] [zway] SENDING: ( 01 03 00 16 EA )
[2022-04-07 18:28:15.786] [D] [zway] RECEIVED ACK
[2022-04-07 18:28:15.786] [I] [zway] Removing job: Abort data send
[2022-04-07 18:28:15.796] [D] [zway] SENDING (cb 0x50): ( 01 09 00 13 3D 02 98 40 25 50 77 )
[2022-04-07 18:28:15.798] [D] [zway] RECEIVED ACK
[2022-04-07 18:28:15.800] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-04-07 18:28:15.800] [D] [zway] SENT ACK
[2022-04-07 18:28:15.800] [D] [zway] Delivered to Z-Wave stack
[2022-04-07 18:28:17.797] [D] [zway] RECEIVED: ( 01 35 01 F8 08 02 01 11 07 05 00 00 00 00 00 00 00 00 38 ED 00 E0 00 00 00 00 01 01 01 01 FF FF 00 00 B0 1C 00 20 78 00 00 00 2D 9B 00 00 2C 9B 00 00 00 00 00 61 01 )
[2022-04-07 18:28:17.797] [D] [zway] Wrong checksum
[2022-04-07 18:28:17.797] [D] [zway] SENT NAK
[2022-04-07 18:28:17.797] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x10
[2022-04-07 18:28:17.797] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x00
[2022-04-07 18:28:17.797] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x0a
[2022-04-07 18:28:17.797] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x07
[2022-04-07 18:28:17.798] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x03
[2022-04-07 18:28:17.798] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x02
[2022-04-07 18:28:17.798] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x07
[2022-04-07 18:28:17.798] [D] [zway] RECEIVED ACK
[2022-04-07 18:28:17.798] [W] [zway] Received ACK, but there's no job awaiting ACK
[2022-04-07 18:28:17.798] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x5e
[2022-04-07 18:28:17.798] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x98
[2022-04-07 18:28:17.798] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x9f
[2022-04-07 18:28:17.798] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x6c
[2022-04-07 18:28:17.798] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x56
[2022-04-07 18:28:17.798] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x55
[2022-04-07 18:28:17.798] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x00
[2022-04-07 18:28:17.799] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0xd4
[2022-04-07 18:28:17.799] [D] [zway] RECEIVED: ( 01 10 00 0A 07 00 03 02 07 06 5E 98 9F 6C 56 55 00 D4 )
[2022-04-07 18:28:17.799] [D] [zway] SENT ACK
[2022-04-07 18:28:17.800] [W] [zway] No job of class 0x0a is waiting for callback 0x07
[2022-04-07 18:28:17.800] [I] [zway] Unhandled callback for function 0x00
[2022-04-07 18:28:17.800] [I] [zway] Removing job: Unknown function class
[2022-04-07 18:28:19.993] [D] [zway] Job 0x3b (Get background noise level): removing duplicate
