i have installed the new board i received today in my rpi, but i cannot get it to connect.
i get
Notification: critical (z-wave): Can not start Z-Wave binding: Error: Binding with name 'zway' already exists
/bin/ls: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.26, BuildID[sha1]=0x7f981e03f231371c5feaaeab28d9e23639e57cd3, stripped
Linux raspberrypi 3.12.35+ #730 PREEMPT Fri Dec 19 18:31:24 GMT 2014 armv6l GNU/Linux
Z-Way version v2.0.0 from 2014-12-08 19:54:26 +0300 (build a064f5408850947aed035bc9170e1fa04f0fd2ec)
Module modzwave.so loaded
Module moddhs.so loaded
Module modenocean.so loaded
Module modhomekit.so loaded
cURL 7.26.0 likely has DNS timeout bug. Please update cURL. Disabling sync DNS timeouts for now.
Module modhttp.so loaded
Module modws.so loaded
dmesg http://paste.debian.net/137477
i actually cannot get it to do anything right now, there is a date of 05.12.14 on the board and the rpi is a b+
On first power on the leds flash red/green but then go off.
Serial port to Z-Wave dongle in the UI is /dev/ttyAMA0, i have run rpi-update and did full updates on all software.
