Tested via this way:
wget http://localhost:8083/ZAutomation/api/v ... ommand/off &
wget http://localhost:8083/ZAutomation/api/v ... command/on &
May be you have some complex rules that are slow to work?
Issue - Update device from api
Re: Issue - Update device from api
Thanks for the test.
Then we know that it should work, now i have to dig in my system to find why it does not work on my system.
Well i do not have any complex rules right now, this dummy devices is added to the If Then app, that's it.
How can i read the temperature level from fibaro motion sernsor using above commands, I've tried everything with no success.PoltoS wrote:Tested via this way:
you mean request new value? update
and read it from metrics
yes. give me an example please.
Thank You
Thank You
