Issue - Update device from api
Re: Issue - Update device from api
Tested via this way:
wget http://localhost:8083/ZAutomation/api/v ... ommand/off &
wget http://localhost:8083/ZAutomation/api/v ... command/on &
May be you have some complex rules that are slow to work?
Isaksson
Post by Isaksson »
Thanks for the test.
Then we know that it should work, now i have to dig in my system to find why it does not work on my system.
Well i do not have any complex rules right now, this dummy devices is added to the If Then app, that's it.
LOCOSP
Post by LOCOSP »
PoltoS wrote:Tested via this way:
How can i read the temperature level from fibaro motion sernsor using above commands, I've tried everything with no success.
you mean request new value? update
and read it from metrics
LOCOSP
Post by LOCOSP »
yes. give me an example please.
Thank You :)
