Android Z-Way 0.2.8 can't connect to v2.0.1-rc4
LAN-Opfer
Post by LAN-Opfer »
...but I see a warning in the Dashboard:
Warning:
[DEBUG] Status report requested
Type: debug
Timestamp: 17/12/14-12:47
Z-Way v2.0.1-rc18 on Raspberry Pi
Re: Android Z-Way 0.2.8 can't connect to v2.0.1-rc4
Can you provide log from server? Few lines from connection process. We will also update the app in a few days as it was released pretty buggy this time
LAN-Opfer
Post by LAN-Opfer »
I tried it at 17:08
  • [2014-12-19 17:07:55.061] [D] [zway] SENT ACK
    [2014-12-19 17:07:55.062] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-19 17:07:55.062] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-19 17:07:55.062] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-19 17:07:55.063] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-19 17:07:55.063] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-19 17:08:28.394] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-19 17:08:28.394] [D] [zway] SENT ACK
    [2014-12-19 17:08:28.394] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-19 17:08:28.395] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-19 17:08:28.395] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-19 17:08:28.396] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-19 17:08:28.396] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-19 17:08:45.378] [core] Notification: debug (debug): Status report requested
    [2014-12-19 17:09:01.727] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-19 17:09:01.727] [D] [zway] SENT ACK
    [2014-12-19 17:09:01.727] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-19 17:09:01.728] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-19 17:09:01.728] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-19 17:09:01.728] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-19 17:09:01.729] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-19 17:09:08.481] [D] [zway] RECEIVED: ( 01 08 00 04 00 05 02 84 07 77 )
    [2014-12-19 17:09:08.481] [D] [zway] SENT ACK
    [2014-12-19 17:09:08.481] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
    [2014-12-19 17:09:08.482] [zway] Node 5:0 CC Wakeup: Wakeup notification
    [2014-12-19 17:09:08.482] [D] [zway] SETDATA devices.5.instances.0.commandClasses.132.data.lastWakeup = 1419005348 (0x54944da4)
    [2014-12-19 17:09:08.482] [D] [zway] SETDATA devices.5.data.isAwake = True
    [2014-12-19 17:09:08.482] [D] [zway] SETDATA devices.5.data.lastSend = 44276 (0x0000acf4)
    [2014-12-19 17:09:08.482] [D] [zway] SETDATA devices.5.data.lastNonceGet = 43276 (0x0000a90c)
    [2014-12-19 17:09:08.482] [D] [zway] Running wakeup handler for node 5
I have also send a Report from my Smartphone - the App crashed
Uwe
It has been updated. Did it helped?
LAN-Opfer
Post by LAN-Opfer »
...not really :-(
The app does not Crash any more - but I got an error: "Can't connect"
  • [2014-12-25 21:36:50.633] [D] [zway] Job 0x13: deleted from queue
    [2014-12-25 21:37:16.818] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-25 21:37:16.819] [D] [zway] SENT ACK
    [2014-12-25 21:37:16.819] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-25 21:37:16.819] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-25 21:37:16.820] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-25 21:37:16.820] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-25 21:37:16.820] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-25 21:37:50.151] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-25 21:37:50.152] [D] [zway] SENT ACK
    [2014-12-25 21:37:50.152] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-25 21:37:50.152] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-25 21:37:50.153] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-25 21:37:50.153] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-25 21:37:50.153] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-25 21:37:55.604] [core] Notification: debug (debug): Status report requested
    [2014-12-25 21:38:23.485] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-25 21:38:23.485] [D] [zway] SENT ACK
    [2014-12-25 21:38:23.485] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-25 21:38:23.485] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-25 21:38:23.486] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-25 21:38:23.486] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-25 21:38:23.486] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-25 21:38:56.818] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-25 21:38:56.818] [D] [zway] SENT ACK
Can you create new profile and make search in local network for the box? Are you sure your phone is in the same Wifi network? Or you are trying to connect via remote access?
Z-Way log will not help... we need tcpdump trace. But this is way more complicated.
LAN-Opfer
Post by LAN-Opfer »
I tried to connect to 192.168.178.46:8083 - but I get the error "Can't connect!"
LAN-Opfer
Post by LAN-Opfer »
PoltoS wrote:Z-Way log will not help... we need tcpdump trace. But this is way more complicated.
...perhaps a special version which creates some debug-informations, will help...
can you connect from browser on the SAME phone? Can you make "tcpdump -w ff -ntl port 8083" and send us "ff" file. If possible, with connection from App and from the browser.
LAN-Opfer
Post by LAN-Opfer »
is it possible without root? I have a new Sony Z1 Compact and do not want to root ist.
Could you explain the steps?
Uwe
