Using switch doesn't update software
RoadRunnr
Post by RoadRunnr »
Hello all,
I am new to Z-Wave>me, so far I like how it works.
2 things I'm having rouble with is.
1. When I turn on any of my switches manually it doesn't update the software.
2. Temp sensors showing in metric, would like to change that to imperial.
I'm using a Raspberry Pi 4 with a Razberry hat, running firmware 5.37
What else information can I provide to help solve these issues?
Thank you for your Help
Re: Using switch doesn't update software
1. Make sure to set up association in group #1 to 1:0 (if Multichannel association is possible or #1 if not).
2. Edit your config/Defaults.xml - there are two values for C/F. After that force interview for your sensors
RoadRunnr
Post by RoadRunnr »
I have been trying to figure out how to do this, I can't seem to get the app to work, and I haven't figured out how to edit the Defaults.xml
is there in installation guide that goes through this kind of stuff?
No simple guide for this.
Open in any editor /opt/z-way-server/config/Defaults.xml and change in two places <Fahrenheit>0</Fahrenheit> to <Fahrenheit>1</Fahrenheit>
