cant update z-station firmware or bootloader.
seattleneil
Re: cant update z-station firmware or bootloader.
Post by seattleneil »
Hmm. The detective work by @lanbrown adds credibility to the guess that Z-Wave.Me could be on life support. Perhaps @PoltoS is trying to sell the company.
Unfortunately, if I take the perspective of a potential buyer, it's hard to see how a purchase makes business sense given their shrinking market share, availability of open-source Z-Wave JS UI (see: https://github.com/zwave-js/zwave-js-ui) and less expensive 800-series hardware (see: https://www.thesmartesthouse.com/produc ... le-zac93-l). As best as I can tell, the real value of the company is the knowledge/experience of the developers and @lanbrown's research shows the developers have moved on.
I'm guessing the downward spiral accelerated a few months ago when the 700-series chipsets used by Z-Wave.Me were deprecated by Silicon Labs for their 800-series chipsets. If Z-Wave.Me was a healthy company, I think they would have introduced 800-series based products.
Time will tell.
pdekuewit
Post by pdekuewit »
What would be a good alternative for a z-wave.me installation on a raspberry pi 4 in combination with Razberry Pro 7 (keeping the hardware) ?
This in case of new developments on the z-wave.me software are stopped completely ?
enbemokel
Post by enbemokel »
I think there are different solutions to use our zwave products in future, HA, OpenHab, IOBroker....depends on personal
ideas or knowledge. I´m testing these systems like once a year, but so far I have everything running with Z-Way and it still works....
lanbrown
Post by lanbrown »
seattleneil wrote: ↑
04 Feb 2025 23:51
Time will tell.
There was a 600 series chip that Z-Wave.me never used either. I viewed the odd number chips as a revised chip but nothing really new was added. I think the 800 series might have some lower power consumption but not as important in the controller side. Intel used the Tick-Tock approach for many years.
https://en.wikipedia.org/wiki/Tick–tock_model
From Silabs:
Power consumption
The Z-Wave 800 series reduces current consumption by up to 42% for transmission and up to 600% for reception.
Since the controller is not a battery powered device, this is not important.
So they would take the existing architecture and just release it on a new process node. So if there were issues, it wasn't the architecture but the process node.
seattleneil
From what I can tell, a shutdown of Z-Wave.me servers would break the following:
1. Mobile app remote access (LAN access should still work if the local IP address/hostname is configured in the app). It's entirely possible the app has a built-in kill switch where the app needs to successfully check in with a Z-Wave.me server. As a result, the app might stop working.
2. Remote web access
3. Voice assistant and ecosystem integrations such as Amazon Alexa and Google Home
4. Cloud backups/restores
5. Forum access
6. Firmware/software downloads, including Apps
7. Support (to the extent it exists)
In addition, @PoltoS could disable public access to github Z-Wave.me repositories.
Can you think of anything else?
As for alternatives, I've experimented with a few different options and found Home Assistant to be the best alternative for my needs, followed by OpenHAB. Both of these options are much more resource intensive than Z-Way - a Pi 4 will be fine, a Pi 3 will likely have RAM challenges, a Pi 2 is not going to work.
The biggest hurdle is the learning curve and time/effort to switch to a new automation platform.
The next challenge is dealing with remote access. With Z-Way, remote access is conveniently built into the mobile app and is free (where the app connects to a Z-Wave.me server and the server connects to the user's Z-Way via zbw_connect/ssh). Web-based remote access (via https://find.z-wave.me/) is also free. Remote access via Home Assistant requires using Home Assistant Cloud (not free) or a VPN (not as convenient).
At this point, I've signed up for Oracle's cloud service which offere a free VM (see: https://www.oracle.com/cloud/free/ - AMD Compute Instance). This provides a VM with a static public IP address that I use to run an OpenVPN server. On my Pi running Z-Way, mobile phone and PC, I've installed the OpenVPN client. This approach lets me use the Z-Way remote app without relying on a Z-Wave.me server by configuring the app with the remote IP address that's associated with the Pi's VPN address. The downside of using a VPN is that it's not as convenient as using the app's built-in secure connection. This same approach should work for the Home Assistant remote app.
What viable options have you found?
lanbrown
Post by lanbrown »
05 Feb 2025 20:10
So it appears that the Github repositories were recently all made public. So I doubt that they will revert them.
I use HA on a CM4 and Z-Wave as an add-on.
For remote access I use Cloudflare and control via ASN and Geo based upon IP address. I also block known torrent sites. So the HA app uses well the cloud I built. Cloudflare has a free tier which works just fine.
Hey guys, sorry for being silent. I like your detective work, but let me do the official Z-Wave.Me coming out ;)
https://forum.z-wave.me/viewtopic.php?f ... 0&p=100028
