I am using the motion detector Everspring SP103. It is associated to the Razberry, but when the motion is triggered, the UI does not get updated.
I can see these messages on log:
Trigger on:
[2013-10-09 08:01:13.191] RECEIVED: ( 01 09 00 04 00 04 03 20 01 01 D5 )
[2013-10-09 08:01:13.194] SENT ACK
[2013-10-09 08:01:13.197] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2013-10-09 08:01:13.200] SETDATA devices.1.instances.0.commandClasses.32.data.level = 1 (0x00000001)
Trigger off:
[2013-10-09 08:02:03.043] RECEIVED: ( 01 09 00 04 00 04 03 20 01 00 D4 )
[2013-10-09 08:02:03.046] SENT ACK
[2013-10-09 08:02:03.049] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2013-10-09 08:02:03.052] SETDATA devices.1.instances.0.commandClasses.32.data.level = 0 (0x00000000)
The lastReceived value is always 0. Is this an error or is it the expected value? The UI always shows the sensor as "idle". I am using z-way version 1.4. Before I was using v.1.3.1 and it worked fine (the UI changed correctly).
I also noticed in the log this message the first time there is a motion triggered:
"Got frame from device 4 to controller, but command class 0x20 for device is not registered - instantiating it as not supported"
Motion Trigger not updating UI
version 1.4. Issues
Hi Pastic,
I've been noticing similar problems recently regarding version 1.4. (I'm having the same issue with both of my Aeon Multisensors which were also previously working perfectly before version 1.4 came out - I wish to hell I hadn't updated the software). I believe the software is the problem though (i.e. version 1.4 is the problem) and not your hardware. Myself and others are having similar problems with z-wave modules. The only forum request regarding this that I can see getting updates/help is http://de.z-wave.me/node/830 supposidly we are getting another update soon so that might fix the problem.
Also, this thread (same sort of issie with version 1.4): http://en.z-wave.me/content/aeon-labs-m ... -interview
Thanks for the info. Let's
Thanks for the info. Let's hope this can be fixed soon if the problem is in the z-way software update.
Hi Pastic,
Hi Pastic,
You are very welcome!
Are you able to revert back to the Z-Way version v.1.3.1?
I just tried this and it worked thus solving all of my problems. Now my Z-wave devices are all working again! The fault is definitely with version 1.4 for sure!!
You can revert back to v1.3.1
You can revert back to v1.3.1 or try out v1.4.1-rc1 (beta). Once it is confirmed to be ok, we will release it
Where can I find v1.4.1-rc1
Where can I find v1.4.1-rc1 (beta)?
edit: I found it here http://razberry.z-wave.me/z-way-server- ... .1-rc1.tgz
Problem fixed in v1.4.1-rc1
I tried the new version v1.4.1-rc1 and the problem is fixed. The UI updates correctly the sensor value.
The log also confirms the value is updated.
[2013-10-24 15:26:52.757] RECEIVED: ( 01 09 00 04 00 05 03 20 01 FF 2A )
[2013-10-24 15:26:52.759] SENT ACK
[2013-10-24 15:26:52.760] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2013-10-24 15:26:52.761] SETDATA devices.1.instances.0.commandClasses.32.data.level = 255 (0x000000ff)
[2013-10-24 15:26:52.762] SETDATA devices.5.instances.0.commandClasses.48.data.1.level = True
[2013-10-24 15:26:52.763] SETDATA devices.5.instances.0.commandClasses.48.data.1 = Empty
[2013-10-24 15:26:55.601] RECEIVED: ( 01 09 00 04 00 05 03 20 01 00 D5 )
[2013-10-24 15:26:55.603] SENT ACK
[2013-10-24 15:26:55.604] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2013-10-24 15:26:55.605] SETDATA devices.1.instances.0.commandClasses.32.data.level = 0 (0x00000000)
[2013-10-24 15:26:55.606] SETDATA devices.5.instances.0.commandClasses.48.data.1.level = False
[2013-10-24 15:26:55.607] SETDATA devices.5.instances.0.commandClasses.48.data.1 = Empty
Thanks!
Thanks!
