I ran the install command "wget -q -O - http://razberry.z-wave.me/install | sudo bash" restarted and can't access the website according to the included manual.
in the logs there is this
"start-stop-daemon: unable to start z-way-server (No such file or directory)"
Install not working
installed on brand new 2013
installed on brand new 2013-02-09-wheezy image
Did you un- and re-plug the
Did you un- and re-plug the power supply of the raspberry to re-boot after installation?
I had some error message when typing only "reboot" after the installation. Then un- and re-plugged and everything worked fine.
Please run the install script
Please run the install script again and see error messages. May be there were some you missed?
You might want to clean /opt/z-way-server folder before.
Also make sure to do sync before rebooting - may be the stuff was lost during power off? We will include sync in next version of install script.
I have the same problem
I've installed on 2012-08-08-wheezy (Soft-float, because I need to run Java) and run sudo apt-get update and sudo apt-get upgrade before installing z-way-server. I'm also getting "start-stop-daemon: unable to start z-way-server (No such file or directory)". I tried reinstall and did a sync before rebooting. Also tried with un- and re-plug the power supply as suggested by Johnny, but that didn't work either...
If I go to /opt/z-way-server and run sudo ./z-way-server I get:
sudo: unable to execute ./z-way-server: No such file or directory
this is certainly due to hard
this is certainly due to hard/soft FP. We support latest wheezy.
Try to do:
file /opt/z-way-server/z-way-server /bin/ls
to see the difference
Try to do:
new
I have got exactly the same issue. The file command revealed nothing.
/opt/z-way-server/z-way-server ..., dynamically linked (uses shared libs), for GNU/Linux 3.6.3, not stripped.
Note that I ve tried with both Wheezy version. 2012-08-08-wheezy and 2013-02-09-wheezy
Did you find a solution.
I'm stuck. Thanks
I'm stuck. Thanks
Both distro with soft float
Both distro with soft float point? We do not support it yet. Please use hard fp. If there would be a lot of requests, we will make another build for soft fp. But as far as we know, Java is not ported experimentally on hard fp.
Same problem
I get the same error message "No such file or directory". I hve updated and upgraded my Wheezy but I still get the same error. When I go to the web browser i cannot connect to the demo UI.
What should I check?
This usually means missing
This usually means missing libs or wrong executable formats. You can try
LD_LIBRARY_PATH=libs strace -f ./z-way-server
to have a look on problematic sysem call
