New version of RaZberry is released
Please make a backup and send
Please make a backup and send it to us with your log file.
dthavot
Device icon state problem in UI in 1.4
Post by dthavot »
Hello, I upgraded my razberry 1.4 RC1 to 1.4 and there is a problem with my FB windows / door device icon not change state on the map when I open the door. In 1.3.1 or 1.4-RC1, it worked like a charm. I reset the controller, the excluded device, re-included, nothing changes, the device icon is still green. the problem persists in all interfaces. In / var / log / Z-way.log all looks normal when I open or close the magnetic sensor, against in / var / log / z-way-server.log nothing happens. do you have a solution?
Bjorn
Seems to have the same
Post by Bjorn »
Seems to have the same problem. No reaction when binary sensors are triggered - goes both for Fibaro Door/Window sensor and an Aeon Labs Multisensor (motion).
dthavot
not alone
Post by dthavot »
hi, i am happy not to be alone having this trouble. Do you come from a 1.4-RC1? when you upgraded your z-way all your map/aera config was preverved ? i will try to reinstall fresh z-way to see if something change.
Bjorn
I came from 1.3.1, due to a
Post by Bjorn »
I came from 1.3.1, due to a mistake (trigger happy clicking) I lost all my devices and had to re-include them. So I started more or less from scratch.
pz1
Just some information for
Post by pz1 »
Just some information for what it is worth:
I did a complete new install of both Wheezy (using NOOBS-install) and version 1.4 of Razberry. It seemed I lost my configuration. Only the devices where there with their proper numbers. I could have restored the latest backup, but because that was very experimental, I tried to rescue, as none of the devices were responding. I did the following:
1) Under network management "Reset Controller"
2) In the same menu "Request NIF from all device"
3) Under "Devices configuration" for every device in section "Select Z-Wave Device Description Record" I did a "Request NIF".
4) In "Expert Mode" for every device in section "Advanced acttions" I did a "Force re-interview"
After a while most of the switches appeared to work again. I had to repeat (and wake some battery devices) a couple of times. But eventually all devices were functional again.
This is just a record of what I did. I don't know if all my actions actually do make sense.
Indeed this is a change in
Indeed this is a change in SensorBinary Command Class. We have fixed this in daily snapshot. We will accumulate some fixes and publish it this week as 1.4.1
gertjuhh
Any news
Post by gertjuhh »
Any news on the 1.4.1 release?
I'm really starting to miss my Fibaro door/window sensors...
Silversquasher
Any news about a new release ?
Post by Silversquasher »
I have the same problem :(
my whole system is inoperative with 1.4 release
We need a solution
Thanks.
Pitt13
DLNA ?
Post by Pitt13 »
I thought a few things may be interesting to include in the next version: DLNA to send images on a television or music, or sentence on a speaker. What do you think ?
