Thermostat
pacaj2am
Thermostat
Post by pacaj2am »
I just wonder howto change thermostat setpoint for my thermostat. I would assume, that command:
http://raspberrypi.lan:8083/ZWaveAPI/Ru ... figSet(27)
would change the value to 29 Degrees. But I receive error. I tried both userSet and configSet.
Could you, please, help?
Thank you
Jan
pz1
Which thermostat do you have
Post by pz1 »
Which thermostat do you have? In case it is a Danfoss Living Connect, remember the temperature setting range is 4-28 Centigrade.
pacaj2am
yes
Post by pacaj2am »
Danfoss... Oops... I spent several hours... :-(
pacaj2am
I'm still not sucessfull
Post by pacaj2am »
Even with lower temperature, that is in range. :-(
the method is called Set, not
the method is called Set, not configSet. Please check the manual on the razberry.zw-ave.me site.
pacaj2am
i found solution... :-)
Post by pacaj2am »
razberry.lan:8083/ZWaveAPI/Run/devices[5].instances[0].commandClasses[67].Set(1,23)
this sets the Danfoss Valve to 23°C... Even 22.5°C works...
pacaj2am
I have still question
Post by pacaj2am »
null is returned. Is that correct?
Yes, it is. The function
Yes, it is. The function returns nothing if succeed and an exception is case of error
pacaj2am
ok, super... i will bring
Post by pacaj2am »
ok, super... i will bring decision logic on it...
thank you
jan
