Possible Hardware Failure
mlavengood
Post by mlavengood »
I have been using my Razberry for about 2 weeks successfully. Yesterday is stopped controlling the one switch that I have set up. I tried a reboot, a shutdown, reseat the Razberry and reinstalling the z-way-server and I am still unable to pull up the page on :8083. Here is the last part of the log after reinstalling z-way-server. In assistance is appreciated.
[2013-04-17 21:55:59.410] Worker thread entry point
[2013-04-17 21:55:59.420] Adding job: Get controller info and supported function classes
[2013-04-17 21:55:59.423] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2013-04-17 21:55:59.603] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2013-04-17 21:55:59.615] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2013-04-17 21:55:59.795] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2013-04-17 21:55:59.807] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2013-04-17 21:55:59.987] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2013-04-17 21:55:59.987] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2013-04-17 21:55:59.988] Job 0x07 (Get controller info and supported function classes): fail
[2013-04-17 21:55:59.988] Get Serial API Capabilities returned zero.
[2013-04-17 21:55:59.988] Removing job: Get controller info and supported function classes
failed to discover ZWay: -9
Z-Way release 2013-03-29 02:09:39 +0400 5d3085259a6f9c9a3305d383d535be645c04bc5e
Starting Z-Way for device /dev/ttyAMA0...
It seems the /dev/ttyAMA0 is
It seems the /dev/ttyAMA0 is not responding.
There are two possibilities:
- you (or apt-get) have changed some params in /etc/inittab and kernel params. Please check
- the h/w was damaged
in the latter case you just need to get a replacement from your shop and send us your board (we want to inspect the h/w failure). We will instruct you how to recover your network on the new RaZberry board.
mlavengood
Here is my inittab
Here is the last part of my inittab. Should there be a line under the comment for the Raspberry?
# Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
# What to do when CTRL-ALT-DEL is pressed.
ca:12345:ctrlaltdel:/sbin/shutdown -t1 -a -r now
# Action on special keypress (ALT-UpArrow).
#kb::kbrequest:/bin/echo "Keyboard Request--edit /etc/inittab to let this work."
# What to do when the power fails/returns.
pf::powerwait:/etc/init.d/powerfail start
pn::powerfailnow:/etc/init.d/powerfail now
po::powerokwait:/etc/init.d/powerfail stop
# /sbin/getty invocations for the runlevels.
# The "id" field MUST be the same as the last
# characters of the device (after "tty").
# Format:
# Note that on most Debian systems tty7 is used by the X Window System,
# so if you want to add more getty's go ahead but skip tty7 if you run X.
1:2345:respawn:/sbin/getty --noclear 38400 tty1
2:23:respawn:/sbin/getty 38400 tty2
3:23:respawn:/sbin/getty 38400 tty3
4:23:respawn:/sbin/getty 38400 tty4
5:23:respawn:/sbin/getty 38400 tty5
6:23:respawn:/sbin/getty 38400 tty6
# Example how to put a getty on a serial line (for a terminal)
#T0:23:respawn:/sbin/getty -L ttyS0 9600 vt100
#T1:23:respawn:/sbin/getty -L ttyS1 9600 vt100
# Example how to put a getty on a modem line.
#T3:23:respawn:/sbin/mgetty -x0 -s 57600 ttyS3
#Spawn a getty on Raspberry Pi serial line
seems to be ok. and the
seems to be ok. and the kernel command lines?
mlavengood
Kernel Command Lines
Here is the link in my /boot/cmdline.txt
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
Well, we see no reasonable
Well, we see no reasonable explanation. Please contact your shop to send it back and ask for a replacement. We would like to get this particular board from your shop in terms of RMA to investigate the problem.
