Cannot startup RazBerry
Apotropaic
Exact log error message
Post by Apotropaic »
Hi PoltoS
Can you please describe the exact log line/s I should be looking for, I am now on my second Razberry card after a RMA and I still have the same symptoms. I am now re-installing my raspbian OS but it would help me to understand exactly which line indicates the wrong firmware is present and what should the correct line be.
Is it - [2013-10-16 18:17:16.633] SETDATA controller.data.vendor = "Z-Wave.Me"
macpiciu
Just received a replacement board
Post by macpiciu »
worked like a charm from first boot
We have investigated the
We have investigated the issue. It seems that there is a problem in initialization code of the board.
Apotropaic
Board Initialization Code
I can confirm the echo commands have healed the replacement device I have.
Minux
Re: Cannot startup RazBerry
Post by Minux »
Hello, i'm new user of raspberry pi B+ and razberry. I try to launch z-wave-server but i have an error.
when i run this command on a new razbian image i get this:
wget -q -O - http://razberry.z-wave.me/install | sudo bash
Start mongoose http server
ls: impossible d'accéder à config/zddx/*.xml: Aucun fichier ou dossier de ce type
Usage: ./z-cfg-update <filename>
Starting z-way-server
Starting z-way-server: done.
Thank you for using RaZberry!
I cannot reach the user interface on port http://myaddress:8083.
when i run this command i get this:
10:12 pi@raspberrypi /opt/z-way-server % sudo LD_LIBRARY_PATH=./libs .
/z-way-server
Z-Way version v1.7.2 from 2014-07-26 15:20:00 +0400 (build 428d48e765a32b39615c073af93e8666497724c9)
Starting Z-Way for device /dev/ttyAMA0...
failed to discover ZWay: Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
zsh: exit 255 sudo LD_LIBRARY_PATH=./libs ./z-way-server
And when looking in to the log, the log file shows : "No controller device found"
[2014-10-25 23:19:00.167] Loading Command Classes for device 230
[2014-10-25 23:19:00.167] Loading Command Classes for device 231
[2014-10-25 23:19:00.168] Loading Command Classes for device 232
[2014-10-25 23:19:00.168] Job 0x02 (Get initial data about network devices): success
[2014-10-25 23:19:00.171] Adding job: Set controller node information frame
[2014-10-25 23:19:00.171] No controller device found
[2014-10-25 23:19:00.171] Removing job: Get initial data about network devices
[2014-10-25 23:19:00.173] SENDING (cb 0x01): ( 01 04 00 62 01 98 )
[2014-10-25 23:19:00.184] Worker thread exit point
[2014-10-25 23:19:00.185] Worker thread successfully finished
Do you have an idea ?
Must i replace my razberry device?
thanks for your help.
Try this first:
echo -ne "\x01\x04\x00\x42\x01\xB8" > /dev/ttyAMA0
echo -ne "\x01\x03\x00\x08\xf4" > /dev/ttyAMA0
And restart Z-Way.
What is the date written on your RaZberry? Is it 14.09.2014?
Minux
Post by Minux »
ok thanks for help; but after one day of inactivity; i don't know why but the razberry working fine. I just shut down my raspberry for 10 hours; unplug the razberry, inspect it, and plug it and it works . i can not explain. Can you tell me what is exactly this command ?
the build date of my razberry is 17.09.2014.
nag
Post by nag »
Same error, date 14.09.2014
So RMA ?
nag
Post by nag »
It's OK.
I just shutdown my RPI 2 minutes, unplug razberry .... plug it and boot ..
Now it's works ..
Cortland
Contact:
Post by Cortland »
I have a new Razberry that was showing "Notification: critical (z-wave): Can not start Z-Wave binding: Error: Bad data - communication failed" in the logs. After about 30 nervous minutes searching the forum, THIS is the magic incantation that brought my Razberry to life. Thanks.
