Some Problems with setting values in new Version.
As sample Fibaro Motion sensor - Parameter24 (should be set to 4 for Seismograph - as I learned from Fibaro....)
After loading XML I see:
N°24 - TAMPER OPERATION MODES:
Updated: 16:56
Default value is unknown
Parameter determines the behaviour of tamper and how it reports
Configuration Parameter type is not handled in the Interface: constant
So it can not be changed
Same for some other important Parameters....
(Maybe it is an XML error/feature - but I think it could be handled here
Michael
[edit]:
Found it out - there is wrong XML -
wrong:
<configParam number="24" type="constant" size="1" default="00">
right:
<configParam number="24" type="rangemapped" size="1" default="00">
same for other Parameters...
