Dolam the italian user, have downloaded the last HA but still the Roller Shutter doesn't work.
Hi Shepotronic,
are your shutter roller working now?
Home Automation - Roller Shutter
Re: Home Automation - Roller Shutter
Anybody can help?
We have not tested much blinds in HA. Hope to do it in coming days
My friend have loaded an old image with the version 1.5.0 and the old HA. He can see now the Roller Shutter in HA but as a Dimmer.
Using 1.7.0 and the latest HA, nothing
should work in latest github commit - tested on my FGRM-222
I have update Z-Way to 1.7.1-rc2 and HA.
On UI Expert I can see the Roller Shutter (see image 1) but in HA it appears as a Dimmer (see Image 2)
- Image 2
- dolam2.jpg (36.81 KiB) Viewed 15031 times
- Image 1
- dolam1.jpg (44.33 KiB) Viewed 15031 times
This change was after latest rc2. Please try from git.
You mean to update HA UI?
I have another problem with the Roller Shutters:
I have installed two different types, the Fibaro FGR 211 that is working well and the FGRM 222 that is seen as a switch and not as a roller shutter
- dolam4.jpg (18.05 KiB) Viewed 14737 times
- dolam3.jpg (29 KiB) Viewed 14737 times
BetterClimate
I have the same problem with the FIBRARO ROLLER SHUTTER FGRM-222 (Roller Shutter 2).
It is possible to calibrate it, and all the setting work but I can only open and close it.
While the positioning should have improved compared to version FGR-221 it is not possible.
It looks like the Multi-level-switch command class is missing?
