Fibaro FGBS-001
Fibaro FGBS-001
Someone have tried to install this sensor? It semmse Z-way cannot see it
Re: Fibaro FGBS-001
I am using this without problems since RaZ 1.3. I must admit that I haven't (re)included it since version 1.5
Re: Fibaro FGBS-001
May I ask you what are your monitoring and how it appears on UI expert and UI HA?
If you can post some pictures would be great
Re: Fibaro FGBS-001
I'm monitoring one temperature and two switches. The switches are shown in the HA as an alarm sensor I think. The icon looks like a person running away. The only connected temperature sensor just indicates the temperature. The remaining unconnected sensor display zero degrees centigrade
Re: Fibaro FGBS-001
Hello pz1, could you describe what steps you followed to recognize the sensor from the z-way? 've done some reset the sensor? if you've made me describe the reset procedure, thank you very much for your time and sorry for my google translation
Re: Fibaro FGBS-001
I do not remember exactly, as it was quite a time ago. What I do remember is that I had one DS18B20 connected to the device before I included it. At the first try it did not show any sensors.
The other thing you should consider is to Force re-interview. You find that in the Expert user interface under the menu Device configuration- Advanced actions. After the interview again open advanced actions, and look at the Review Results
Re: Fibaro FGBS-001
Hi pz1,pz1 wrote:I'm monitoring one temperature and two switches. The switches are shown in the HA as an alarm sensor I think. The icon looks like a person running away. The only connected temperature sensor just indicates the temperature. The remaining unconnected sensor display zero degrees centigrade
I'm able to see only three alarm sensors set 'on' and nothing more.
I have connected a device DS18B20 so I'm expecting to see a temperature.
Is there any association or any particular setting to do?
- guarda il tuo multisensore2.jpg (31.86 KiB) Viewed 21296 times
- guarda il tuo multisensore.jpg (36.66 KiB) Viewed 21296 times
Re: Fibaro FGBS-001
donepz1 wrote: After the interview again open advanced actions, and look at the Review Results
this is how it appears but still only three alarms sensor are visible. no way to see temperature
- guarda il tuo multisensore3.jpg (35.86 KiB) Viewed 21186 times
Re: Fibaro FGBS-001
The third sensor which shows up as alarm takes the postion of the first temperature sensor. May it be that the DS18B20 is not properly connected? I assume you anly connected one temperature sensor!?
Re: Fibaro FGBS-001
Please give a look to the scketch below. I have just one DS18B20 and I tried to report in a 3d shape below. Is the first one on left closer to the device.pz1 wrote:The third sensor which shows up as alarm takes the postion of the first temperature sensor. May it be that the DS18B20 is not properly connected? I assume you anly connected one temperature sensor!?
thanks for your help
- guarda il tuo multisensore5.jpg (23.11 KiB) Viewed 21014 times
