Home Automation - Roller Shutter
dolam
Re: Home Automation - Roller Shutter
Post by dolam »
There is another small problem in version 1.7.1 is no longer possible to see the new device in the tree and it is therefore not possible to place them on the map.
does not show the device in tree
Think you can solve it,
Thank you always for your help.
we will remove that tree and the map from the Blue UI anyway. It is a technical UI and we are rewriting it.
dolam
Post by dolam »
I'm sorry, it was very convenient to place the device on the map, :?: :?:
dolam
Post by dolam »
You can not rename the device FGRM - 222 last installed, it happens to you?
dolam
Post by dolam »
I upgraded to the latest official version 1.7.1 released and roller shutter are back to not allow any more settings here's an example.
What can I do to fix this? Thanks to all those who want to help
http://s29.postimg.org/iq8zpo3jr/Scherm ... _13_08.png
SolarFlor
Post by SolarFlor »
I believe you have solved now. Just repeating the procedure.
@PoltoS,
could you include the changes needed to have the Roller Shutter Fibaro 222 integrated in the system so that at the next update everything will work?
dolam
Post by dolam »
Yes, I repeated the procedure you had indicated that you and eric Orae and back to work,
tank's
dolam
Post by dolam »
Polto's I'm sorry if I renew my request, but if you can not delete the map function in UI Expert, I think it's really nice is very helpful.
So if you can not remove, thanks and ever thanks for the splendid public work that you gave us.
Sorry for my english use google translator
http://s15.postimg.org/dp58i4fgb/Scherm ... _47_59.png
http://s23.postimg.org/3o9g1aagb/Scherm ... _40_07.png
Eric
Post by Eric »
I agree with dolam that a map view is nice for large setups. But probably it should be re-implemented in the new interface in some way. Now that the old interface is becoming the expert UI it doesn't really belong there anymore.
@dolam:
We are thinking to "re-invent" it in the new UI in future, since the old Blue UI is based on Z-Wave directly and not on abstract concepts introduced in automation engine.
But keep calm, the old Blue UI will be kept for a year at least.
