How to Update the status of a Device
SolarFlor
Post by SolarFlor »
Some devices like the Binary Power switch of Aeolabs are not updating automatically their status in UI.
I mean to see the real status of the device on UI Expert I need to update it manualy (pushing the key 'update').
Is there any way to do it automatically?
Re: How to Update the status of a Device
Polling or set up Report group if the device supports it
SolarFlor
Post by SolarFlor »
You mean to use "Poll Sensor Periodically" whitin Automation?
I cannot see it in the list of device.
How I could set up Report Group?
In the blue UI you can set up Association groups
SolarFlor
Post by SolarFlor »
Yes, but what I should do exactly?
see configuration below
I've never used that device ;)
sdh
Post by sdh »
Set the config parameter 80 to value 2, telling the device to send basic CC Report. The default value is 0, so no reports are sent.
Aeon MSES Par80.tiff
Aeon MSES Par80.tiff (70.59 KiB) Viewed 19445 times
SolarFlor
Post by SolarFlor »
Many thanks for your suggestion. I would like to try immediatelly but, sorry for the stupid question, how?
I have tried to edit 450-0086-0003-001a-03-03-28-03-00.xml but I have not find parameter 80 there
<?xml version="1.0" encoding="utf-8"?>
<ZWaveDevice xmlns="http://www.pepper1.net/zwavedb/xml-schemata/z-wave" schemaVersion="2">
  <descriptorVersion>1</descriptorVersion>
  <deviceData>
            <manufacturerId value="0086"/>
        <productType value="0003"/>
    <productId value="001a"/>
    <libType value="03"/>
    <protoVersion value="03"/>
    <protoSubVersion value="28"/>
    <appVersion value="03"/>
    <appSubVersion value="00"/>
        <basicClass value="04"/>
            <genericClass value="10"/>
            <specificClass value="01"/>
        <optional value="true"/>
    <listening value="true"/>
    <routing value="true"/>
        <beamSensor>0</beamSensor>
      </deviceData>
  <deviceDescription>
                <description>
            <lang xml:lang="de"></lang>
            <lang xml:lang="en">Switching Insert</lang>
          </description>
            <wakeupNote>
            <lang xml:lang="en">Single click on inclusion button</lang>
          </wakeupNote>
            <inclusionNote>
          </inclusionNote>
            <productName>MES</productName>
            <brandName>Aeolabs MES</brandName>
            <productLine>MES</productLine>
                            </deviceDescription>
    <commandClasses>
        <commandClass id="0020" inNIF="false"/>
        <commandClass id="0085"/>
        <commandClass id="0086"/>
        <commandClass id="0027"/>
        <commandClass id="002b"/>
        <commandClass id="002c"/>
        <commandClass id="0070"/>
        <commandClass id="0072" version="2"/>
        <commandClass id="0025"/>
      </commandClasses>
    <assocGroups>
        <assocGroup number="2" maxNodes="5">
            <description>
                <lang xml:lang="en"></lang>
              </description>
          </assocGroup>
        <assocGroup number="1" maxNodes="5">
            <description>
              </description>
          </assocGroup>
      </assocGroups>
SolarFlor
Post by SolarFlor »
Found it.
In Expert Command I set value 2 to Parameter 80 and .....
... it works.
I can now see the updated status on all UIs.
Many thanks sdh.
Last question: where I can found the explanation of all parameter configuration? I mean the document where you extract the picture you posted above.
Thanks again
sdh
Post by sdh »
Just write to support at Aeon Labs and they will send them. I have them for Micro Smart Energy Switch 2E, Micro Smart Energy Illuminator 2E and 4-in1 Multi Sensor. I can forward the mail to you if you want.
