Forest Motorized System
pofs
Re: Forest Motorized System
Post by pofs »
I think you should consult with your vendor support and ask them how to link curtain shutter with remote when remote is not a primary controller.
Remote doesn't support association groups (or at least it doesn't expose it directly). Probably the linked node can be set via COMMAND_CLASS_CONTROLLER_REPLICATION, but we don't support it. You can try to send a raw command, but no guarantee it'd help:
/ZWaveAPI/Run/SendData(A,[0x21,0x31,0,1,B])
where A is your remote node id, and B is your curtain shutter node id.
The other thing to try is transfer a scene info:
/ZWaveAPI/Run/SendData(A,[0x21,0x33,0,2,B,50])
This should set level 50 to scene 2. If this works, you could setup other scenes as well.
johnm
Post by johnm »
In desperation, I bought the GE 45600 Z-Wave remote control. I paired it with the Razberry and it shows up as a device.
However I don't see association groups anywhere in the expert UI? Is this supposed to show up under the curtain motor or under the remote, or elsewhere? Thanks
Looks like yours is not just rebrended, but have different firmware and does not support any command classes except for COMMAND_CLASS_MANUFACTURER_SPECIFIC.
I'm not sure you can configure it from RaZberry - once included, use the way described in the manual of that device.
johnm
Post by johnm »
Thanks for the reply Poltorak. I'm not sure if you're referring to the GE remote or the original remote that I had for my curtain?
Where should the association groups show up in Razberry, under the curtain or the remote?
In the Remote
